Sway bar end links?
Old Jan 31, 2008 | 12:12 PM
  #31
ptgarcia's Avatar
Since you have a 2" spacer I'd say you need to do the end links.
Old Jan 31, 2008 | 12:16 PM
  #32
Bikinaz's Avatar
Originally Posted by megaboom
im doing the lazar smith sssss and the endlinks i know i dont need to do the endlinks with the sssss but im just gonna do it to have hd ones so i dont have to worry about them later on
I'm pretty sure the LazarSmith sector shaft stabizer also lowers your stablizer bar. You will not need extended length end links then, but you may need stronger ones. Just something to think about.
Old Jan 31, 2008 | 12:27 PM
  #33
megaboom's Avatar
well the carli endlinks are good for 0-3" of lift and i would guess the lorenz ones are too so even if im using the sssss i should be able use them because they are adjustable, right?
Old Oct 13, 2010 | 08:13 PM
  #34
weezer's Avatar
Do the Carli links come with the rubber or poly bushings?
Old Oct 13, 2010 | 10:36 PM
  #35
Nsomniac05's Avatar
"Stainless Steel Sway Bar End Links
Carli's adjustable stainless endlinks are machined out of the highest quality 17-4 stainless material making them a lifetime product. Each endlink goes through a five stage machining process. At the end of each endlink is a 1/2 inch F.K. nylon lined bearing to replace the much weaker factory ball and socket design.
SPECIFICATIONS
Adjustable for 0 to 3 Inches of Lift
Machined out of 17-4 Stainless Steel "
http://www.thecarlisuspension.com/do.../endlinks.html
Old Oct 14, 2010 | 03:36 AM
  #36
weezer's Avatar
So what's at the other end of each endlink?
I did a little more research The Lorenz links are the same basic design with the same question. It looks like you use your old rubber or buy your own new set. For $200+ I think it's crazy they don't supply them.
jk6140
Mar 9, 2008 08:22 PM
oldblues
Jun 25, 2007 11:12 PM
68dodge
Jun 25, 2006 11:28 PM
Inferno Ram
Jun 11, 2006 10:53 AM
