superior shft kit for 48re
installed shift kit yesterday and it works awesome, 1,2 shifts are bit closer and much firmer, lock up is sweet now, no more slipping with the tst on 7/6, new program,awesome kit for the money, was 98.00 can. took me 2 hrs to install, replace many springs, valves, and lots of drilling.
the kit is made by shift technology and i got it at a diesel performance shop in edmonton alb. it cost 98.00 can, and is a total valve body kit, and works awesome, it slams the torque when its time to lock it like it should as all shifts are very firm and fast, worth every dollar.
yes blygy from barry at nadp, did all their testing on chips for the 325/600 when they came out, part # is k500-618-L by shift technologies or superior trans, works awesome do it now before its too late
no just the valve body, you even have to put a resistor in line with your line pressure wire to trick the computer in thinking it has the same line pressure, still working good.
YES bywanye it changes all the shifts and makes 2/3 closer, has a full time lube, no more delay in gear, rapid fill manual valve, and locks very firm as apposed to before
coolslice
02-05-2005 03:58 PM
