Superchips Flashpaq question
Old Mar 6, 2010 | 08:26 PM
ddszero's Avatar
Question Superchips Flashpaq question
Hello, I am new and trying to gather some more information and learn more about my truck and what I can do and shouldn't do. I just got a Superchips Flashpaq for my truck and put put the turner to the Tow-Performance mode. My MPGs jumped from 18 to 24 while I was on the highway. That was hand calculated too .
Well I was wondering what do I need to keep an eye on? my truck is mainly stock only with a K&N drop in filter. I have a pryo and boost gauge on order to install. I have noticed when accelerate heavy I produce more black smoke now. I typical try to keep from that, is that something that can become a problem?
Thanks
__________________________________________________ ______________________
2005 2500 Crew Cab short bed 4x4 with a NV5600 3.73 With Limited Slip
111,000 Miles, K&N Drop in filter
12K Mile Marker Front Mounted winch
BFG KO AT 285/70 R15
LEER Camper Shell (my puppies BIG Kennel)
Old Mar 7, 2010 | 01:30 PM
tcr's Avatar
tcr
Your going to have more smoke w/ the additional fueling of the SCs, you need those gauges asap and let your truck cool down before you shut it off(wait 45-90 secs). Your air filter is good and clean isn't it, a dirty filter will cause more smoke as well.
Old Mar 7, 2010 | 09:43 PM
ddszero's Avatar
Yes, I clean my air filter every 10,000 miles and make sure it completely dry before I oil it and reinstall it. Thanks for the info. Whats the best gauges to have? Boost, Pryo, anything else?
Old Mar 8, 2010 | 07:41 AM
tcr's Avatar
tcr
On yours w/ a manual tranny; I'd install #1 a lift pump fuel pressure and #2 a rail pressure gauge if you have the funds.
Old Mar 8, 2010 | 11:48 AM
ddszero's Avatar
Yes I have the 6 speed NV5600. Which has been a jumpy in both foreword (first and second gear) and reverse since a shop replaced the clutch pack when my through out barring went out.
Old Mar 14, 2010 | 07:44 PM
SSdiesel's Avatar
Hey ddszero...how do you like that Superchips Flashpaq? I was looking at the Cortex...need to be able to adjust speedo for new tires & want to get as much as possible out pf a gallon of fuel.
Old Mar 15, 2010 | 10:00 AM
tn hillbilly's Avatar
I ran a Flashpaq on mine before I sold it. I borrowed it from my buddy, and he wanted me to buy it. The truck had a little more pep, but to me it wasn't worth the $200 dollars he wanted for it. If you are going to run it, you need to get a Boost, Pyro, and Fuel Pressure gauge at a minimum. The EGT's don't stay too hot for too long, but will jump up for a bit. I recommend saving up and getting a Smarty instead.
Marshall
Old Mar 26, 2010 | 05:13 PM
ddszero's Avatar
Well I am like the better mileage and power. After replacing my fuel filter and cleaning me air filter it my truck is not pushing much smoke at all. I have been getting 20 city and 25 highway (hand calculated) I have not been pushing it at all, I am waiting on my gauges to come in so I can make sure I don't run my truck to hard. Also making sure I had the correct tire size has helped. I cannot complain, it is good starting point and I did not pay an arm and a leg for it. I Might get a Smarty latter on after I up grade my exhaust.
__________________________________________________ __________________________________
112,000 Miles, K&N Drop in filter
J.T
13
Jun 20, 2006 05:01 PM
chuck gibson
Apr 25, 2006 12:02 AM
MonroeDiesel
Mar 30, 2006 03:00 PM
