Strange noises since clutch replacement
Old Jan 16, 2008 | 12:43 AM
OutHuntin''s Avatar
A couple buddies and me installed my SB OFE about 7,000 miles ago and ever since there has been very noticable clatter/rattle from the clutch. It is usually a mild noise but sometimes it gets pretty loud to the point that it sounds like some damage is being done. Is this normal? Recently my tranny has also been making a loud whinning noise when at idle whether the clutch is engaged or disengaged. The noise goes away with a little throttle. Its hard to describe the noises in words but any advise or guesses would be appreciated. Thanks in advance.
Old Jan 16, 2008 | 09:25 AM
jp8819's Avatar
If its only when idling in neutral with clutch pedal out you are prob hearing some rattle in the clutch plate.
Old Jan 16, 2008 | 09:36 AM
JCLeary's Avatar
That doesn't sound right to me...
My OFE was quiet as stock.
Old Jan 16, 2008 | 10:00 AM
jlibert's Avatar
mine is quiet, no noise whatsoever.
Old Jan 16, 2008 | 11:39 AM
snoyes's Avatar
If it was a DD it would almost be normal.. I don't think the single should be rattling. Something sounds wrong. When you push down on the clutch does the noise go away?
Old Jan 16, 2008 | 03:35 PM
OutHuntin''s Avatar
Yeah, the noise disappears when i push down on the clutch. I hate to pull the tranny again but I think it is going to happen before too long. The rattle is just too much to be normal.
Old Jan 17, 2008 | 08:02 AM
jeff-kc9ftp's Avatar
same problem w/ mine
Installed new ofe, flywheel and upgraded hydraulics. Noise was terrible, i thought I'd put something together wrong. I was told to put about 800-1000 miles on it to let it break-in. It never got any better. I finally pulled it back apart, everything looked ok. I did add some grease( hi-temp disc brake type) to the shaft the throw-out bearing rides on and I also removed a shim/washer behind the ball pivot stud.
I don't know which one fixed it but one sure did. I still get a little noise idling with the clutch out but it is a lot quieter than what I had before.
Unfortunately, I think I'm going to have to do it all over again. This time for a dual disc set-up. Playing with the smarty betas I've slipped the OFE a few times, now.
jeff s.
Old Jan 17, 2008 | 08:36 AM
walexa's Avatar
Probably the best thing to do is call peter at SBC and see what he says. It is my understanding that they are now using a heavier clutch disc center and more noise may be normal. I had a SB ofe in for a couple years and it was quiet as stock, but like I said, I think the ofe has now been upgraded to a heavier center.
Waylan
Old Jan 17, 2008 | 02:39 PM
OutHuntin''s Avatar
Thanks for the advice guys. I will probably call SB this afternoon to see what they say.
nofender
17
Dec 19, 2007 06:02 PM
kevlar
Jan 9, 2006 09:19 AM
Chrisreyn
Jul 5, 2005 08:02 AM
JAF
May 28, 2005 12:56 AM
7421f
Dec 13, 2004 11:34 AM
