Are stock dually wheel studs long enough....
Old Jan 27, 2008 | 05:50 PM
Dodgezilla's Avatar
If you run a 1/2" spacer? I'm going to be putting some 265s on and just want to be sure they won't rub but I also want to make sure the studs are not going to need to be replaced. I may go with 1/4" if 1/2" will be a problem....
Old Jan 27, 2008 | 07:11 PM
Speed Shift's Avatar
I think you will be ok, just pull off your center caps and see how much thread you have left. I know 1/4" spacers will fit no problem.
Old Jan 28, 2008 | 09:20 AM
homewrecker's Avatar
This is 265's with a 1/4" spacer.I tried running 1/2" and the threads did not come past the top of the lugnuts.
Old Jan 28, 2008 | 09:33 AM
cgmorgan06's Avatar
I am running 265's right now without any rubbing issues.
Old Jan 28, 2008 | 10:15 AM
Dodgezilla's Avatar
Thanks men. I found a company on e-bay that sells 5/16" spacers. I may go that route just for the heck of it....
It does look like there's plenty of space between those tires....
Old Jan 28, 2008 | 01:25 PM
DieselBoy20's Avatar
You'll be alright with 265's without a spacer. Toyo MT's are prob one of the most aggresive tires on the market for mudders right now and 265's will fit on a dually without spacers no problem. 285's ya you'll have problems.
Old Jan 28, 2008 | 02:41 PM
Dodgezilla's Avatar
Thanks....
Old Jan 28, 2008 | 07:00 PM
metalbasher's Avatar
I ran 285's with 1/4 inch spacers and they fit good, the nuts were flush with the end of the threads, so not totally ideal, but they are hub centric so I wasn't that worried. I actually bought the 1/2 inch spacers and couldn't use them, and there are no longer studs available either.
Old Jan 29, 2008 | 02:07 AM
RRC's Avatar
RRC
Did you tow heavy? If so what was your pin weight like? I tow a 40' 5er and between pin weight/firewood/misc. stuff it's over 4k pounds, would I be ok you think? They would be an E rated 285 toyo????
Old Jan 29, 2008 | 07:24 AM
Just look at the pic posted earlier of my 265's.No way a 285 is going to be that much space.I think a minimum of a 1" spacer will be required for all the people wanting to tow with a 285.
Old Jan 29, 2008 | 08:34 AM
abc4yew's Avatar
Homewrecker, I thought that was my picture at first....a 1/4" looks better than mine. The Coopers in the pix are the widest 265's I've seen and I have them with no spacer and they don't touch even when loaded to the max and then some but you need full air if you are hauling heavy...duhhh!ks
Old Jan 29, 2008 | 08:46 AM
I run my rears at about 60lbs,helps with the ride quality and I don't tow heavy enough to cause any sidewall sag.
Old Jan 29, 2008 | 05:22 PM
TrinityTrucking's Avatar
whats up guys ,,,if you were towing heavy ,,would the space between the tires be enough gap,,,,i pull about 30k daily ,,and i wanted to get 265's
Old Jan 29, 2008 | 11:06 PM
Pinksa's Avatar
Ive got a friend with 265's with no spacers and he hauls heavy..Just air them up good
Old Jan 30, 2008 | 04:23 AM
Dodgezilla's Avatar
Here's how I see it after all the replies. They will fit with no spacers but you have to keep them aired up when towing. If I forget to air them up then I may have a problem if I tow heavy. 5/16" Spacers are about $25.00 for a pair. I think I'll get the spacers because I know I will forget to air them up.....
