stock 04.5 600 turbo strength???type??
now that i have my clutch in i've been playing around w/ the tst box a bit. it seems on 3/3 or any higher when this little thing spools it does it quick and very hard ;almost smacking 40psi than dropping down to about 34-35psi or so. can any harm be done to these turbos fueling it like that? should i be keeping the numbers down on the boxes until i get something tougher; turbo wise? heat is not a big deal at this point; i'm not in it for that long to build a ton of heat. just want some smoke at times but it sounds kind of violent at say 5x5. also, what kind of holset is it? electronic wastegate control type; my35? not sure . thanks everyone
The stock 600 turbo is a Holset HY35 with a 9cm housing. I ran the TST box on 6-6 and just had the stock wastegate. i would hit around 46psi, however i knew i was goin to get a bigger charger. my suggestion would be to leave your wastegate alone, because just about anyone i have talked to has blown their stock turbo with the wastegate closed. I would also be looking to upgrade your turbo so you can use all 9 levels
. why have all that power and not use it
Originally Posted by hovisimo
what exactly causes a turbo to "blow" - curious because i've never seen it happen?
keep the torque number at 1 or 2 if you want it to live
play with the HP number all you want (until temps get too high of course)
Originally Posted by gman07
Not to steal the thread or anything, but what turbos are on the 555 and the 610? Don't the 610's have electronic wastegate control like an HE351CW or something like that?
yes
the 555 is mechanically controlled wastegate
and the 600 and 610 is electric controlled wastegate
so there is no "boost elbow" for the 600 or 610
Originally Posted by Agades
yes
for my model year; tst supplies a boost elbow of some sort that clamps onto the line that you pull from electronic turbo mounted solonoid rendering the solonoid usless. the line that now contains the boost elbow is run under the engine block to manifold pressure through a boost bolt wastegating it in a conventional manner. i think
kram
Aug 29, 2007 11:01 AM
KATOOM
Dec 2, 2003 11:00 AM
