hardwiring an Ipod to an 05 stereo
Old Oct 24, 2005 | 12:34 PM
Honkylips's Avatar
What's the best way to go about doing this? Do the stock stereos have aux inputs?
Old Oct 24, 2005 | 12:40 PM
John Rodriguez's Avatar
Tire Hater
Go buy a cheapie radio deck at BestBuy with aux inputs. I bought a nice Sony deck with Aux input, the Belkin RCA to 3.5 sterio jack, and installed it.
Old Oct 24, 2005 | 01:56 PM
nickleinonen's Avatar
there are some aftermarket wiring harness things that attach to the stock deck to let you feed an aux. signal into it. i can't find the link in my bookmarks, but someone here must have it... [will keep looking for it]
Old Oct 24, 2005 | 02:53 PM
grow_ctd's Avatar
Alpine ipod control module
Ive got an Alpine Ai net head unit with a Ipod control module from Alpine It is pretty cool if you are into saving the quality of your music transfer. It plugs into the factory Ipod port allows the head unit to give you a read out of song selection and the head unit then controls going through the songs as though the Ipod Was a giant Cd changer. Complete digital transfere of music no sound quality loss... Check it out I cant recall part numbers off hand but if you need them let me know I can look it up later
Old Oct 24, 2005 | 04:17 PM
walt_mink's Avatar
You can easily add an iPod controller to your '05 factory unit unless you already have an external unit. For instance, I have the Sirius unit - so no go for me. That also applies to the BlueTooth module if I recall correctly. Call Crutchfield - they can get you the right part and they provide good install instructions.
Walt_Mink
Old Oct 24, 2005 | 04:45 PM
BTDodge4x4's Avatar
Cool iCruze
Go to Crutchfield.com and look up the iCruze. It hooks into the factory radio and allows you to control the iPod through the radio. It is awesome and its sound quality is way better than the other options.
Bryce
Old Oct 24, 2005 | 10:05 PM
DarkPaladin's Avatar
Says it doesn't work with built in CD changer, so my Infinity system is a no go. ((
Old Oct 24, 2005 | 11:34 PM
BTDodge4x4's Avatar
Cool CD Changer
It will work in place of your CD changer, you just can't use them both at the same time, but if you have your iPod hooked up what's the point of having a CD Changer?
Bryce
Old Oct 25, 2005 | 09:53 AM
walt_mink's Avatar
It won't work in conjuntion with an external cd changer. It will be okay with the infinity system if you don't have a satalite or bluetooth module.
Old Oct 25, 2005 | 10:51 AM
TRAVIST's Avatar
I have my sirius radio hardwired through and aux input that plugs into the cd changer port on the back of the radio. I got it from this place www.logjamelectronics.com/piechry02aux.html. It worked awesome for me as it eliminated the fm modulator which sucked.
Old Oct 25, 2005 | 03:23 PM
1tuffdiesel's Avatar
Guys, are you sure it will work with the factory in dash cd changer? Crutchfield's website says the following:
What you need to know:
» Vehicle must NOT have the factory navigation system.
» Factory radio must have a button labeled "DISC UP" and another button
labeled "DISC DOWN".
» You will need to disconnect the factory CD changer, if you have one, and connect the new adapter in its place.
» The factory radio must not have a built in CD changer.
» Adapter plugs into the factory radio.
» If you have the factory satellite radio option, it will no longer work with this adaptor.
» The Crutchfield MasterSheet, if available, does not cover OEM integration.
I've been trying to find a way to hardwire my iPod in but there just doesn't seem to be an option out there if you have the in dash 6 disc changer. The Pie Adapter has the same disclosure.
Karl
Old Oct 25, 2005 | 04:05 PM
BTDodge4x4's Avatar
I would imagine that since you have the built in CD Changer you will have to swap it out for a different factory radio. I have the RAZ model radio. I just got the iCruze in the mail the other day. I will update you guys once I get it installed and let you know how it goes.
Bryce
Old Oct 25, 2005 | 04:20 PM
Ya, I think I'm going to have to go that route as well. The problem is the RBQ model doesn't have CD changer controls since the changer is actually built in. The RAZ model does seem to be the way to go if you want to keep the factory look like I do. I wonder where you can find stock units for reasonable prices?
Karl
Old Oct 25, 2005 | 06:10 PM
slimpicken's Avatar
TRAVIST
Does that little jobber just plug into the square port on the back of the radio? Can you control the siruis receiver through your radio? Does your radio have the six disk changer. Is the sound quality good, and finally is it an in only unit or could you hook an amp to it to run speakers?
thanks in advance for any help,
Nick
Old Oct 26, 2005 | 02:40 PM
The CHRY02-AUX is NOT compatible with the in-dash 6-disc Radio (RBQ) Arghh.. Why didn't they just put an AUX jack in the damned thing......
