Stock 03-04.5 turbo to HE351
Yes the shorter ones work better, I was close to just adding a heavy lock washer on the longer studs and call it good but after a minute of thought... and the old ones broke loose from the 341 turbo fairly easy, it was a no brainer, I swapped them. I did not do as Dodgezilla said, but maybe I should have on the inner studs, but then again I used 24" of extension and a 20" breaker bar to tighten and they did tighten, so I think I'm good but will monitor.
UNDER-PRESSURE
308
Oct 18, 2015 07:58 PM
5.9 Blackout
May 26, 2011 08:11 PM
Big Blue24
Nov 27, 2008 12:36 PM
PaulDaisy
19
Oct 8, 2008 12:05 PM
