Stacking the Smarty
Soulezoo says: Yes, for all intents and purposes you can stack six-gun with Smarty. The results you see will differ on the individual truck, year and whether or not you have the pda. The smarty is so strong that the amount you see with the banks will be small. This is in direct relationship to the Smarty program and level you use. For example: if you use Smarty stock TM with stock injectors/stock turbo on SW1, 2 or 3 you will see a difference when turning up the Banks to a certain degree. If you are running Beta 4.4 on SW9 you will see only a very slight difference with Banks turned all the way up. Bottom line-- Banks in todays world is a weak fueling box that really doesn't like to be stacked and is not made to play well with others. Banks makes his stuff to be HIS stuff.
Soulezoo says: Buy a Smarty and ditch the Banks and you will be
in the long run.
If you have no plans on bombing your truck or modifying any further, then keep the Banks (it is a lot of $) and be happy.
in the long run.If you have no plans on bombing your truck or modifying any further, then keep the Banks (it is a lot of $) and be happy.
How bout pulling with the smarty? I know it'l kick *** hp wise, but I pull 12,000-15000 pounds pretty much every day so its gotta do that good. The banks does a great job of it? How are the egts with the smarty. I have water/meth so it won't be a huge problem if thats all I have to worry about. I just know the bully dog sucked at pulling and my truck felt like it was dying the whole time, but the banks really pulls good and has no problems
pulling with a smarty can get quite hot, not to mention sooting up your trailer.
i tow on level 3, and my temps are manageable, but i have alot of air available, single turbo it got hot.
click on shop dtr. we sell them here.
