stacking programmers
Old Nov 17, 2007 | 03:14 PM
smoky05's Avatar
right now i am stacking a triple dog with my edge hot juice. i am thinking about swapping my bullydog for a smarty. what will stack better with the edge? also what is the best stack? any feedback would be greatly appreciated.
Old Nov 17, 2007 | 03:21 PM
bighornram's Avatar
smarty and edge don't play well together - so i've heard. Seems most are saying that Smarty/TST is the best stack right now.
Old Nov 17, 2007 | 03:27 PM
smoky05's Avatar
this may be a dumb question but what is the tst? never heard of it
Old Nov 17, 2007 | 03:51 PM
bighornram's Avatar
TST is a fueling module - check out www.tsperformance.com Their MP-8 pressure box works well with many programmers and boxes that don't already add pressure (like Smarty)
Old Nov 17, 2007 | 04:20 PM
jwb600's Avatar
the tst will stack better with the bully dog or a smarty. but its a box that will need some supporting mods like a fuel system etc
Old Nov 17, 2007 | 04:42 PM
Speed Shift's Avatar
TST and TS are two different companies.
There is a TS MP8 pressure box, and a TST powermax CR that will do timming, pressure, and duration.
http://www.tstproducts.com
Old Nov 18, 2007 | 04:25 PM
bighornram's Avatar
Yeah I realized shortly after posting that that I was wrong. Thanks for the correction. I don't like giving bad info.
Old Nov 18, 2007 | 04:38 PM
CReed's Avatar
Smarty does timing and duration on odd #s and duration only on evens. The software version 2.4.1 from bullydog has lots of timing and duration in it with no pressure at all are you noticing any timing rattle when you use the two together I would be willing to bet you are the edge does timing as well this can me damaging over a long period of time. I would recommend the smarty with the use of like stated above a tst with minimal at most 2 or 3 degrees added timing wise play with the power levels and add some pressure with either the tst or stack a ts mp-8 with the smarty and tst. The way the tst and the mp-8 add pressure are a little different. A turbo will be needed as egt's will be extremely high no matter which way you go, also a aftermarket lift pump like a gdp or a fass is recomended.
ram3qrtton4x422
Jul 27, 2008 04:03 PM
yellowhemi
May 20, 2008 09:29 PM
DGraham1023
Dec 24, 2007 10:42 AM
holeshotking1
Jan 31, 2007 05:53 PM
DieselGoose
Jun 20, 2005 09:08 PM
