stacking edge
Do a search for "stacking" and you will find alot of useful information. Most guys stack the edge juice with a fuel pressure type of box like the edge ez or the ramifier. I think the hottest setup is the mp8 stack with the juice. To run that kind of power you better be setup with guages, intake, and clutch etc. Fill out your signature so folks can see exactly what you have. It helps when making suggestions.
abuddy of mine with a 06; 6-speed has the bully dog crazy larry, the 280hp download stacked with the edge juice... it runs good, but he had to put his fass system on it soon, cause it was running out of fuel from 4th gear on... and he is still on a stock clutch too... man them 06' clutches can handle a load!!!
Originally Posted by mung
thanks, do you suggest anything else beside stacking, stock tranny now, looking into centerforce clutch, whats the highest boost i can go without getting a stud kit?
Loved my OFE in my '97, put down 433rwhp, 950ft lbs, no slipping...
Havic801
11-16-2011 02:34 PM
blue2002
11-24-2010 11:46 AM
hotrod929
12-27-2006 11:10 PM
mcevins
08-30-2003 11:09 PM
