Stack install tips
Stack install tips
I just bought a stack kit yesterday.
Does anybody with install experience have any tips to ease the install of these things. Especially cutting the hole in the bed floor, and placement of the mounting clamps.
TIA Jason
Does anybody with install experience have any tips to ease the install of these things. Especially cutting the hole in the bed floor, and placement of the mounting clamps.TIA Jason
I havent seen any 3rd gen setups, but if the frame and such is like the 2nd gens, then you can do how I did. Go from the downpipe, to the bed with steel pipe, then 90 it up, to a 90 over the rail, with flex pipe to a 90 through the bed. Drill some holes and use the clamp through the side of the bed. Hope this helps? Ask member John Rodriguez about his stacks. He has a 3rd gen with them if this doesnt help...
did you buy a pre-made kit, or did you buy the pieces to build your own?
i got a premade kit, the y-pipe had to be set down into the bed floor so instead of a 5" round hole, i ended up with more like a 5"x9" oval to allow for the pipe to recess down into the floor.
Originally Posted by BADBOWTIE
nobody have anything to say?
Greg
Originally Posted by ds1rider
Hey maynard, hows that flowmaster sound?
Greg
I sell and install the grand rock kits 1 thing i do is all the bed work get everything lined up and measured then drill your hole a hole saw work best, install the y-pipe and then do all your under neath work install the bed items then your stack have a level handy to help. not as bad as it looks just take your time, jr
here some pics of my truck with the grand rocks kit on a second gen
this side pic shows how mounted them back about 3" fromt he front of the bed to prevent myself from needing to cut the cross member of the bed up front
like i said earlier, i used a hole saw then a jig saw to "oval out" the hole so the bends of the y-pipe couild sink down and set everything right to the bed of the floor. i assume this is how its supposed to be, but if you wanted to mount it higher you could...but i like the height of my mitre cut stacks at about 5-6" above the cab
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
