SpynTec free spin hub pics.
Old Mar 31, 2009 | 05:51 PM
jumper's Avatar
You could engage 4x4 (while stopped) every once in a while then drive around to spin the front end if you're worried about dry u-joints.
Also better hope that the wife remembers to lock the hubs and doesn't happen to twist that little **** to 4x4 High like she's used to doing while rolling down the road. I imagine that the electric transfer case engagement is much less forgiving than the manual lever that gives instant feedback if the hubs aren't locked.
Old Mar 31, 2009 | 05:53 PM
rjm022's Avatar
pulled my dyna tracs off after having 35,000 miles on them to do my ball joints. truck has seen lots of water and mud off road-the grease looked brand new in mine too.
Old Mar 31, 2009 | 07:30 PM
cbrahs's Avatar
unruly, what did they cost?
Old Mar 31, 2009 | 08:05 PM
bradler's Avatar
I actually throw mine in 4-lo sometimes without the hubs locked in for low gearing in 2wd when backing trailers around in tight spaces. Never seems to be a problem going that slow but i've always wondered what would happen in 4hi without the hubs locked in. Wouldn't the drive shaft, fron diff and axle shafts just spin without putting power the wheels. If I grab the front driveshaft and just spin it by hand nothing bad happens, axle shafts just spin. Not sure how you would get feedback in t-case if hubs aren't locked?
Old Apr 1, 2009 | 02:46 PM
Obben's Avatar
I´ve tried to reach Solid Axels for a while, both by mail, phone and through the onlineshop, but cant get a hold of them. Where did you purchase your kit?
Old Apr 1, 2009 | 04:18 PM
UnrulyNFS's Avatar
I called Solid Axle almost a year ago to order mine. They said their latest run had just sold out. But then the girl said she new where I could get them, after looking through the order slips, she found that KLMperformance had bought a good portion of the kits. So I called those guys up and ordered a lot more than just the hubs, I also got Carli ball joints and a few other things. I don't remember the exact cost of the hubs, but I didn't pay what their asking now. I just checked their website and it says almost $2000. Also says they are out of stock.
Old Apr 1, 2009 | 04:19 PM
UnrulyNFS's Avatar
Originally Posted by GlennRMK
What width and backspacing are your wheels?
Looks like they would stick out a lot on stock wheels.
20x10 4.5BS
Old Apr 1, 2009 | 04:22 PM
UnrulyNFS's Avatar
Originally Posted by BLACK PEARL
Any intall pics or with the wheel off?
My brother and I took a bunch and he will probably do a write up. I don't have any I can post.
Old Apr 1, 2009 | 05:17 PM
Obben's Avatar
Great info!
Thanks!
Old Apr 1, 2009 | 06:10 PM
rootercycles's Avatar
I just recently got done putting this SolidAxle SpynTec Kit on and lots of people wanted to see how far the hubs stick out. Steers better, less vibrations, and hopefully better MPG's though I doubt it. Gonna press some new U-joints into the front driveshaft this weekend and get that put back in.
The big advantage to this kit is I can rebuild these hubs both for under $60 as opposed to $400 for a single stock unit bearing. Plus there is less wear and tear on the driveshaft and axle end U-joints since they no longer spin. The new 2wd LOW gear will be nice if I have to back up a trailer as well. :SPIN:
not as pretty as my EMS hubs...yours look great!
Old Apr 4, 2009 | 12:31 PM
Tacsavage's Avatar
I'll try and post a few pics of the install soon. Tac
Old Apr 4, 2009 | 07:53 PM
Danderson's Avatar
Product development anyone?
A cheaper compromise might be a greasable unit bearing.
Old Apr 4, 2009 | 07:56 PM
annabelle's Avatar
I don't think that is an option.
Old Apr 4, 2009 | 07:58 PM
UnrulyNFS's Avatar
You can grease it, but once the bearing is bad, its bad and can't be rebuilt. But your right, it should have a grease fitting somewhere.
Old Apr 5, 2009 | 06:47 AM
I reused the front u-joints in mine when I put the free-spin hubs up front. Hind site, I wish I would have replaced them with serviceable units
