sps62 12 or 14 ???
Old Jul 30, 2008 | 05:58 PM
Floridacracker's Avatar
Question sps62 12 or 14 ???
i do tow often which would be a better turbo for me.. the 12 or 14
i will have a smarty in a few days which will help
are there anyothers i should look at ???
Old Jul 30, 2008 | 06:24 PM
bigman's Avatar
I ran a 62-65-14 before twins and she spooled very fast and i had zero issues with egts even pulling 10k. The 71 wheel spooles a little slower and is tougher to drive the speed limit. Your foot has to be in it to keep egts in check at least thats how my 6 speed with that turbo responds.
Old Jul 30, 2008 | 06:49 PM
i hear alot of people w/ 6 speeds saying good stuff but i need some people w/ autos to chime in
Old Jul 30, 2008 | 06:50 PM
theres a 12 i can get kind of cheap
Old Jul 30, 2008 | 07:09 PM
bigman's Avatar
I have both, an auto and a 6speed currently. I have tried both turbos in both trucks and hands down the 65 spools better and is easier to tow with
Old Jul 30, 2008 | 07:34 PM
homewrecker's Avatar
The 65 is a better towing turbo in my opinion.I have had one and now have the 71 wheel.Trust me when I say, there is some slight lag(71 wheel) with a 6 speed and there will be even more lag on an auto.If towing is your primary concern then 65,if you are willing to compromise a little on spool up for more top end then go with the 71.
Old Jul 30, 2008 | 08:17 PM
but it's a 12 would that be better or worse than a 14
Old Jul 30, 2008 | 08:25 PM
Billy Ram's Avatar
I ran one of the early htb2 62/12s and then switched the turbine housing to the 14. Didn't see much differance other than crusing empty boost was less with the 14. Towing a load there wasn't much differance. Made 500 hp with both.
Old Jul 30, 2008 | 08:26 PM
Sorry,misread the post.If its an sps then it has the 71 wheel.Didn't realize you could get a 12cm housing with the 71.I can't comment on which is better other than the smaller housing should spool slightly better but with slightly higher drive pressures.
Syndicate
May 19, 2006 01:47 PM
cjones42
May 10, 2006 08:49 AM
Reaper
Apr 7, 2006 02:40 AM
metal_miner
Mar 18, 2006 04:36 PM
