spool-up rpm difference...
Old Apr 10, 2009 | 10:39 PM
hotrod929's Avatar
I still cant decide between the HTT 64/65/13ss or 64/71/13ss. Anyone know what the RPM difference in these two lighting will be around with my truck. It will have an airdog, programmer, trans when this goes in just trying to plan ahead. Thanks
HotRod
Old Apr 10, 2009 | 11:42 PM
jgiachino's Avatar
With the auto, i'm thinking 65....what gearing do you have?
Old Apr 11, 2009 | 01:54 PM
rip 112's Avatar
I'd think the difference between the two would be 1-200rpms in initial spoolup. Now the difference from one of these compared to your stocker there is gonna be a considerable difference in low end spoolup. A programmer will help alot but IMO won't spool it up fast enough to your liking. You may find yourself adding some pressure or stix sooner than you would like. Again JMHO.
Old Apr 11, 2009 | 05:12 PM
bigwheels94's Avatar
I was told by the guys @ HTT that the difference was about 400 rpm between the 65, & 71 wheel. I went with the 65, & it still smokes more than I'd like off the bottom. But it spools very fast for it's size. I'd recomend the 65 with an auto, especially if it's got a stiff T/C, like mine.
Old Apr 18, 2009 | 10:30 PM
gus's 03's Avatar
personaly, i prefer the larger wheel...
the diferance in persure ratios more than makes up for it spooling a tad slower....
Old Apr 19, 2009 | 10:25 AM
Spooler's Avatar
If you have 3.73 gears go with the 65 wheel. It also depends on which TC you have. A tight TC and you are not gonna like it.
jefjsak
Jan 15, 2015 03:44 PM
53 willys
31
Jan 31, 2008 02:24 PM
skeeter
Jan 18, 2006 03:17 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
