speed sensor issue????
hi all
i recently spliced into the speed sensor wire under the fusebox to try and see if she defueled without it,i ran the wire thru a switch and when i broke contact the speedo would go out and get a abs lite on ,well this was working well for the past few weeks but now even with the switch in its closed contact position the speedo stays off,did i screw somthing up,im kinda scared,has anyone else done this with any sucsess?
thanx,oh i tried replacing the switch and i actually went under the fuse box and removed the splice,hope nothing is wrong
1st breaking into any computer wiring can lead to lots of issues , they run on very small voltages & currents that can easily be affected .
That's why the box's are out there .
What codes do you have ?
What is your reasoning behind doing this ?
dan123dbl
02-13-2015 05:47 PM
