Speed limiter?
Old Jan 2, 2008 | 09:26 PM
FastTaco's Avatar
Speed limiter?
How does everybody get rid of it. I have a smarty and thought it would but found out the other night for the first time when I got on a long road. It was pullin hard and wham! like I hit a wall at 108.
Old Jan 2, 2008 | 09:30 PM
CReed's Avatar
What version smarty program are you running that is your problem more then likely. No speed limiter thanks to smarty here.
Old Jan 2, 2008 | 09:38 PM
FastTaco's Avatar
Hmm. I'll have to check. I just got it about a month ago so it should be fairly recent.
Old Jan 2, 2008 | 09:43 PM
soulezoo's Avatar
DTR 1st Sergeant
You have to actually go and change that parameter. There is a selection that asks "speed limiter" then you program the mph you want. If you have to check for it, then you have not done it and so it is the stock limiter.
Plug in the smarty and look for that option... if you don't have it then download the latest file and it has it.
Old Jan 2, 2008 | 09:47 PM
RamWheelsBy4's Avatar
If you have a version that has the Speed Limiter option when you load a Smarty SW # it will have the option to change speed limiter first. I am not sure if the stock software versions have the SL option until you get to the Wild TM.
Old Jan 2, 2008 | 09:48 PM
soulezoo's Avatar
DTR 1st Sergeant
All the TM versions have the SL option.
Old Jan 2, 2008 | 10:11 PM
I thought so, just one of the S04s I sold and loaded on a truck for a friend did not have the SL option. I thought it was a Smarty I had loaded one of the later versions on, but must have been one with previous version before SL came out.
Old Jan 3, 2008 | 07:33 AM
haloman's Avatar
The no SL works really well IMO:
http://www.youtube.com/watch?v=xjI22aEdtkI#GU5U2spHI_4
Old Jan 3, 2008 | 10:35 AM
FastTaco's Avatar
I have version v4.09 d2.08.
Old Jan 3, 2008 | 11:35 AM
FastTaco's Avatar
Just downloaded new software from mads site. Installed the USB driver but the sending program won't send the update. It says its not a smarty file.
Old Jan 3, 2008 | 11:46 AM
soulezoo's Avatar
DTR 1st Sergeant
Is it unzipped already? there is another thread here where AlpineRam posted the pictures for step by step downloading instructions... by far the easiest instructions to follow... Search for that thread in this forum.
Old Jan 3, 2008 | 11:53 AM
FastTaco's Avatar
I needed that 7zip program. Thanks I got it figured out. Now time to go test on truck.
Old Jan 3, 2008 | 12:26 PM
soulezoo's Avatar
DTR 1st Sergeant
http://bisanz.have2.com/smarty/smartyweb.pdf
Glad you got it... for all here is the link to the AlpineRAM instructions.
Old Jan 3, 2008 | 02:38 PM
FastTaco's Avatar
Thanks. Now I got to get my FCA straightened out. Truck keeps surging bad so I've took it out about 3 times and sanded it, turned it 90', got it where it slides good and it still seems to be sticking somehow. I think it might have gone bad so I just ordered one from the dealership for $161. I'll try and get this one perfect before I put it in.
CrashCade
Jul 5, 2005 01:32 AM
dieselrob
13
Apr 9, 2005 10:48 AM
lit up
Nov 27, 2004 11:36 PM
ARAcummins
Oct 24, 2004 09:30 PM
Ttexas25
31
Sep 30, 2004 08:48 AM
