South Bend PN 1947-0 for 03 2500 with mystery mods?
Old Jul 25, 2010 | 04:41 PM
mikespeed95's Avatar
So my truck is down, and I need to find a clutch, I found one locally, but don't understand the coding jib-jab.
"PART NUMBER: 1947-O
FITS: 2000.5-2005.5 FOR NV5600 TRANS. 6 SPEED"
My truck is an 03, with a HO5.9 and a 6 speed, is this what I want?
It has a dyno tune from previous owner, obviously with a slipping clutch throwing it on the dyno is a terrible idea.
All I do with the truck is pull my 42' enclosed that won't see more than 12-13k of stuff, and I'm not a fan of racing 8,000lb vehicles. Daily driver, will this clutch work?
Found it locally from private seller, and The reason I'm confused is because I didn't know they used the same transmission/clutch setup since 2000, which confuses me.
Old Jul 26, 2010 | 07:38 AM
patdaly's Avatar
You should be good to go, but if you are still unsure, call Peter at SBC.
Pretty sure that is just a standard Con-O, doubt you drive thru it.
Only real change in the clutch was the transition to 1-3/8" Input 2001.5
Old Aug 2, 2010 | 02:35 AM
Thanks dude.
Finally pulled it out, turns out this is the same clutch that was in there...which is odd...but it worked absolutely fine until I got injured and my friends drove the truck, so should be fine again.
FiverBob
Apr 12, 2014 08:30 PM
Rick_Orcutt
Jul 2, 2007 09:09 AM
ssleeper94
May 10, 2007 06:34 AM
