Smary Com Chips
Smary Com Chips
Are they good chips? I have an 06 dodge 4x4 3/4 ton I have a Dr. Preformance will I have any prolbems with this chip if I put it on my Truck.. Will the chip burn up my computer?
Thanks Warren
Thanks Warren
I think you are asking about a Smarty Computer chip??
The Smarty is not a "Chip" it is a Downloader / Programmer. It is hooked to your OBDII port and reprograms your ECM and then unhooked.
The Smarty Jr and Sr are both very safe to use if you understand how they work. A lot depends on what you are trying to do and how you use your truck. More info on what you are trying to do will help get better responses.
The Smarty will not hurt your truck's computer/ecm, but it may tear up your transmission if an auto, or your clutch, if standard trans.(If your truck does not have certain upgrades. The higher settings on the Smarty will provide more hp/tq than a stock truck can handle.)
You need to go to the "User CP", upper left corner, click on it, and fill out your "signature" with your trucks information, then we can be of more useful assistance to you.
I am just trying to get better fuel milage My Dr Performance plugs to my fuel Rail under the hood on my truck, I also have a fine tune dial mounted close to the stering wheel under the dash..
( Would changing out the Injectors do anything different to my performance of my truck.)
We need all the info about your truck and where & how you drive. the more info the better. Most people including me have gotten better mileage with the Smarty. As long as you take it easy!!
I dont drive my truck hard. Not trying to tear anything up. I drive it when I go out of town or on vacation. I have a half ton I drove to and from work. ( is the Smarty better than the Bully Dog And Why? If I change out the exaust is that better than factory..
You can go here >>> http://www.dodge-diesel.org/smtubymael.html to compare them.
The Jr has fewer features and fewer levels than the Sr.
mgtbob
May 12, 2008 09:30 PM
oldblu
Apr 5, 2008 11:00 PM
Gas Sucks
24
Dec 23, 2006 10:24 PM
rharveysr
Nov 22, 2006 03:23 PM
" on my truck
