smarty x2 stack
smarty x2 stack
i ended up getting the x2 standard box to stack with my smarty since i have the commander and it comes with the rail gauge. i was just wondering if i load the smarty on sw2 or 3 with factory timing is it safe to run the x2 with the standard files that come loaded on it? it feels like it has a lot more power than running the smarty with default or mpg timing and the x2 stacker files.
thanks
david
thanks
david
i have the revo loaded and that is what i am using. my trans is still stock so i keep it on sw3 but sometimes it is nice to have a little extra when it is time to play. i ran it on sw5 for a while and the trans seemed to hold it fine but i dont trust myself to keep it on that setting all the time. i am trying to find the best way to have adjustable power on the fly with the smarty and x2.
I run the TNT+X2 stack and am more than happy
I have the Smarty on 7, timing 2, RP 2, torque 3, and wastegate off. The X2 has the fuel only without boost fooling downloaded, and I keep it on level 2 usually. If I go over 2 the rail pressure will hit 27K+ without a problem at WOT. At 2 I barely se a blip over 25.5.
I have the Smarty on 7, timing 2, RP 2, torque 3, and wastegate off. The X2 has the fuel only without boost fooling downloaded, and I keep it on level 2 usually. If I go over 2 the rail pressure will hit 27K+ without a problem at WOT. At 2 I barely se a blip over 25.5.witch software you have load on x2?
i have mpg stack load.
i run x2 on 1 and smarty tnt #5
with x2 on 1 i read 23k on rail.
with x2 on 4 around 26.5 k
chris
I run the origional version of the smarty on sw5 and I leave my x2 off unless I want to play and need a little extra. On the x2 I have the standard version loaded with the stackable program in it so that no timing is added except from the smarty. I love it and on wot with the x2 on level 3 I will hit 26.5 on rail preassure almost up to 27 which I think is safe and wont harm anything. some one correct me if Im wrong on that.
Yes, It is safe on the lower levels 1-3. I would load the stacker prg when you can, then you can have at it. I run the beta 4.2 #9 w/ x2 on psi only and it flies. I would like to try an MP-8 though.
325 Race Stack NoBoost. I would use the program with boost fooling but it messes with my boost readings on the Attitude monitor. Gonna have to plum in a boost gauge one day
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
