smarty update???!!
i had to go back an reread the thread. it is possible, gus lives near me, where it rains most days. i got loose in 4th yesterday, 5th may be possible. not on drive pavement with a stock clutch i wouldnt think, but wet, you bet
I love mine! This update is exactly what I was looking for! Now i NEED that bigger turbo to use the full range.....once i get to about 65 I am showing about 1400 on the needle. That is from a 10lb jump to 65....at cruise speeeds I am at 65 and 650*.
THANKS MARCO!!!!!!!!
Well I got the Wild program going in my 2003 with a DTT, it is pretty wild, however on dry pavement I can't break my 35" mudders loose, not even with the pressure box turned on to the max. This really doesn't bother me, cuz tire spinning isn't really my thing and the truck is **** fast now, I just expected this wild version with little to no TM to be able to spin the tires with ease. Oh well!!
I have downloaded the new update for aftermarket injectors with a stock turbo and was wondering if the new update did boost fooling. I have a quad boost fooler and I am getting over 50 lb boost out my stock turbo and I no that won't last long. Before I did the update I was getting around 45lb of boost.
So im just wondering what you guys think of your smarty at the bottom end mostly? I originally was going to get an mp-8 for the bottom end but im thinkin of doin the smarty now. ????
Dang wife has a hard time believing that I need to keep throwin money at the truck to get better mileage, and to tow this "heavy" work trailer. I mostly was thinkin against tha preassure box becouse Im starting to beleive all the hype about tearin up injectors.
oh and as far as wet.. yha.. lighting it up in 6th isnt hard ether..
and congrats on the 500/1k+ results.. that flat rocks!
My question is for my 2006 stock turbo 6 speed
With the new "Smarty S-06A Ver. 4.05A, Data: 3.05A" file ..
(The new "Moderate torque management increase" 12/21/06 19,4364 KB)
Should I, (do I need to), disconnect my Quadzilla Boost fooler with this update????
Big question...
Bump
Big question...
Bump
i have a quad module, which does boost fooling. i had the smarty without the latest fooling software, and my boost stayed where i set it at 47psi. when i put the new fooling program in, and hit it hard, boost went over 50. i had to readjust the wastegate.
the difference may or may have not been the combination of 2 foolers, or just the fact that i have 2 fueling setups and am throwing so much fuel at it.
i would unhook the quad fooler, because your stock turbo isnt going to like those speeds.
duallydave
Aug 27, 2006 02:06 PM
odie2219
25
Mar 9, 2006 06:18 PM
