smarty setting on dyno with a stock trans??
In a few weeks I'm going to put my 06 Cummins on the dyno. I was wondering what setting can i take it to safely with the stock auto trans. I have 5" exhaust, intake and gauges... and the revo program in it now.. any proven settings? should i put the TNT download in it?? Any comments will be appreciated.. Thanks guys!
I dynoed mine on SW9 on stock trans, no issues. 427hp, obviously not getting all the power available to the ground. This was before TNT or Revo came out, but if your not having issues with it, load up TNT SW9, and see what she'll do!!
Wow thats low. That should be, at minimum, ~425hp if not higher.Mine, bone stock other than Smarty (stock intake, exhaust, trans, everything) did 427 on an earlier tune. I was expecting 425 and woulda been disappointed with anything less
I agree with the others. That sounds low. I dyno'd 466 and later 467 on a different dyno with Smarty only. (old version). The 466 was on the stock lift pump and the 467 was with the Walbro....(but I think that was irrelevant in this case).
Your stock trans should be fine for a dyno run, imo. Mine was stock on the above runs.
are you guys pulling in Drive or O/D... I think alot of HP numbers get mixed up when guys pull in different gears... My understanding is that; Drive will get you higher HP numbers, but O/D will get you better TQ numbers...
Also alot of guys seem to see more power on level 7 then level 9
Neight
Feb 15, 2010 05:56 PM
1985cucv
17
Apr 28, 2009 04:59 AM
zylberberg
Jun 17, 2008 01:44 PM
TxDiesel007
Nov 19, 2007 12:26 PM
J Banning
15
Apr 21, 2006 10:50 AM
