What is the highest setting i can run my smarty on with a trans go?
i was wondering what the highest setting i can run my smarty on with the trans go? i have it on sw5 right now. and i am assuming that is as high as im gonna go, but was wondering if i can go higher. i have the trans go done, billet servo cover and super servo, band strut and anchor, gm govenor solenoid and sensor, and billet accumulator check ball removed bands adjusted.
thanks a lot guys
thanks a lot guys
Location: Smith Valley, NV (sometimes Redwood City, CA)
Anything over stock torque is likely to slip the lockup clutch. You can run on any setting you want, but when locked and pulling at lower RPM watch for subtle signs of slipping. If you let it go it will get worse and worse till you can't do much without slipping. Try to pull at higher RPM and, when passing on the highway in OD locked, watch for slipping.
He put in a Transgo shift kit to raise the line pressures.
You can run any setting you want with in reason. Low rpm's and hotter tunes are going to stress the stock TC all the way around. Just keep that in mind as you are playing around and you should be good for a bit.
[QUOTE=no_6_oh_no;2462845]He put in a Transgo shift kit to raise the line pressures.
That's fine, but it doesn't mean a stock converter will hold much over stock torque. Some, but not a lot and it sounds like he wants to go as high as he can. The lockup clutch will be the weak link for low RPM high torque pulling.
I have higher line presure in my new VB and an aftermarket converter (not a triple disk) and it has gotten progressively weaker over he last 60,000 miles. Towing or passing I can slip it at will. And this one is way better than the stock one was.
so your saying that it might be too much power where i have it? i have it set at sw5 tm2 tq2 and rp2
I was actually just wondering what would be safe? i dont really beat on it to bad but i do like to get on it once in a while
For starters its pretty hard to get these trucks into a high TQ low rpm situation with the TC locked without a mystery switch. They will downshift if the rpm's get too low. The Transgo does not override the default behaviour in that aspect, and, it brings full line pressure in by 1600 rpms.
With just the Transgo shift my stocker was holding over 800 ft\lbs of TQ and not slipping. Towing over 10k and never slipped even on grades playing with it.
If the TC is good and one does not totally thrash it the stocker holds up pretty good with a little help. Those are my experiences, but, as always "mileage may vary".
Thats 800 TQ not HP. HP was running around 410.
Here is the direct clutch pack at 104k, 50k of Smarty on a stocker, 12k of shift kit and Smarty. I did Seattle WA to Wilmington NC and back, Seattle to San Diego and back towing 5-7k. It was still holding till it finally cut the apply piston seal. TC would slip on #5 or above in the right conditions before shift kit. Never got it to slip after the shift kit.
Those are pre-rebuild numbers with JUST the shift kit when I was trying to track down the above problem. The guy that rebuilt it tightened things up a bit and with the rebuild they are probably a little better. The direct clutch seal was dumping fluid pretty bad so am sure that was affecting the top numbers.
The whole reason I started looking for a problem was a sudden spike in EGT's of about 100 degrees at times and about 20 degrees more trans temp than I was used to.
Hopefully yours is something simple like leaves or stuff interfering with the flow.
IIRC, it was $200 with a few other parts but I pulled the VB out and put it back in. I had a friend do it for me and I watched while guarding the beer.
i put my own in i would pay someone a hundred to do it but that is about it. i like figiting with things but this is one of them that is like i hope i did it right and i didnt the first time however if you follow the directions spot on you can get it i botched one part and didnt have park. but i got it now and it feels good to say i did it myself
