Smarty Questions
Old Dec 25, 2007 | 05:03 PM
Ghost Ram's Avatar
Smarty Questions
Well im considering purchasing a smarty but i want to make sure it will suit me before dropping the cash. i tow about 3-5k almost everyday for work and i want to make sure the smarty would be good for that as well as future performance goals. my trans is currently stock so i plan on running one of the lower settings for now until i upgrade the trans. what exactly is the catcher software i have been hearing about anyway?
what other mods would be recommended w/ the smarty? i do plan on adding a cfm+ intake and a set of twins in the future as well as building the trans. anything else to consider?
my fuel system is stock, what will i need to upgrade to take full advantage of the smarty later on?
and lastly, w/ a relatively stock truck and towing everyday is the smarty for me at this point? i know the smarty jr. is available but i dont want to waste $$ on it only to have to upgrade later when i want to make alot more power in the future.
Old Dec 25, 2007 | 05:42 PM
jmccart's Avatar
If you are planning on twins, I would cough up the extra dough for the Sr. One thing I have really enjoyed with the Smarty (especially after owning the Superchips and Diablo Predator) is how quickly it changes performance levels.
I have not towed yet, but I will real soon. But I can't believe how much cooler the EGT's are with the Smarty, much cooler than just stock.
Old Dec 25, 2007 | 05:47 PM
Ghost Ram's Avatar
smartys sr.?? thats the regular smarty, correct? if so thats what im interested in, NOT the smarty jr.
i just want to make sure the smarty is for me before purchasing it.
spooling's Avatar
I tow 17,000lbs on levels 3 and 5, HUGE difference way more towing power and lower temps than stock. Really great towing programmer
Old Dec 25, 2007 | 05:48 PM
Ghost Ram's Avatar
how easy is it to change power levels?
Old Dec 25, 2007 | 06:03 PM
Tacsavage's Avatar
I tow 4-5k all the time with mine on level 7. Gauges are important. I think the Smarty will be great on lower settings probably 3 or 5. You'll need a fuel system such as a fass or GDP walbro setup once you start going beyond level 5 after you have trans mods done. Tac
Old Dec 25, 2007 | 06:53 PM
Wv7o's Avatar
Can't you return a Smarty or Smarty Jr. within 30 day's if you decide it is not for you??
Old Dec 25, 2007 | 07:39 PM
high bid's Avatar
Does the Smarty do boost fooling for the ECM or do you need the module for that also? I tow about 5k as well and am looking into this also. thanks.
Old Dec 25, 2007 | 07:47 PM
jmccart's Avatar
If you do the aftermarket turbo downloads it fools the boost. I don't know if that is an option on the Jr.
Thanx.
Old Dec 25, 2007 | 09:38 PM
Ghost Ram's Avatar
so w/ my stock turbo will the smarty add more boost or do i need to run a program for aftermarket turbo's?
i guess i waould like to know what exactly the smarty does to make power on a stock truck, pressure, boost, timing or what?
Old Dec 25, 2007 | 09:58 PM
DrDiesel's Avatar
Wink
Fuel and timing control. No pressure that I know of. I`m running one on my 07 with a build date of 08/06. My TST from my 06 will not work on this newer truck. The smarty`s latest release of software has low EGT`s.
At 40 degrees on a heavy pull up hill from 1500 rpm`s in 6th gear it never topped 1000 degrees.
Old Dec 26, 2007 | 04:26 PM
bluebull's Avatar
Yes............
Old Dec 26, 2007 | 04:27 PM
bluebull's Avatar
Smarty Jr. does boost fooling, timing advance, injector duration.
Old Dec 26, 2007 | 04:32 PM
bluebull's Avatar
Smarty Jr. does boost fooling, timing advance, injector duration. No pressure on the Jr. you have to get the Sr. for pressure. The Jr. was designed for lower EGT's with towing in mind.
Stock turbo will build about 36-38 PSI before the Smarty Jr. program opens the waste gate.
Old Dec 26, 2007 | 06:47 PM
bigwheels94's Avatar
Just got my jr. & when I installed it there were no #'s indicating the different programs. Just Towing, & performance. I did the performance. Thats the 100hp. right? It went in with no problems, & with only 1 run @ WOT, for a few seconds, I note it shifts smoother, & runs good, but I haven't had a chance to realy run it yet.
