Smarty Question!?!?!?!
Old Aug 20, 2007 | 11:50 PM
dirtydemon's Avatar
ALLRIGHT I JUST BOUGHT MY SMARTY ! I HAVE BEEN TOLD I CAN RUN IT ON WHATEVER SETTING I WANT . . . .BUT IT SAYS IN THE SMARTY BOX THAT IT IS ONLY SAFE FOR A STOCK TRANNY ON LEVEL FIVE!? I RAN A BUDDY AND I HAD IT ON 7 TOOK HIM . . . . ON 5 I STOMPED HIS . . . YOU KNOW, BUT IT SEEMED TO PULL HARDER AND FASTER ON 5 THAN 7! I DONT UNDERSTAND. I ALSO CANT HARLDY GET ANY SMOKE ON 5 JUST LITTLE PUFFS.
Old Aug 21, 2007 | 12:03 AM
Convicted1's Avatar
That would most likely be because you are draining your fuel rail.
On level five you are able to keep enough pressure in the rail to atomize the fuel correctly and provide a decent burn.
On Level Seven your fuel rail pressure is too low to atomize the fuel.. thus the decrease in performance.
Edit for Spelling...
Old Aug 21, 2007 | 12:10 AM
dirtydemon's Avatar
I was wondering also if i should run it on even settings or would i see more out of the odd's? can i stack my edge ez with the smarty?
Old Aug 21, 2007 | 12:20 AM
jwb600's Avatar
if you arent running other mods I dont see why you cant run it on odd numbers with timing. I wouldnt go any higher than 5 or so if you dont have thosands to put in your transmission. I run mine on 8 all the time and it smokes pretty decent if you want it to. theres guys on here that have stacked an ez with the smarty. if you think it has too much timing run it on the odd #s
Old Aug 21, 2007 | 12:28 AM
dirtydemon's Avatar
thanks man i just dont want to burn anything up! appreciate the advice though! level 5 shocked me cause it walked off on a bd stacked with an edge ez and the ez was on level 3 and the bd on extreme
Old Aug 21, 2007 | 12:38 AM
jwb600's Avatar
I see you a heavy duty clutch. whats the hp rating that it will handle? you might look into a fuel system if you plan to run the smarty. it will make life on your cp3 easier. I know the smarty & tst together will roll out the smoke.
Old Aug 21, 2007 | 06:59 AM
MikeyB's Avatar
I run on level 5 because of the stock clutch. With the stock lift pump I can drain the rail on the highest setting. Definately need a Glacier or FASS pump.
MikeyB
Old Aug 21, 2007 | 10:09 AM
rip 112's Avatar
Smarty works better on 03-04s than bullydog does, so I wouldn't be too surprised. level 5 smokes mainly when you get on it in the lower rpms and then clears to a haze.
Old Aug 21, 2007 | 11:52 AM
Cummins610's Avatar
dirty demon - What boost are you making with the Quad Fooler & the Smarty?
Old Aug 22, 2007 | 01:29 PM
pupeperson's Avatar
jwb600 said: "if you think it has too much timing run it on the odd #s"
I think that's backwards. If your stack together has too much timing, you want to run the Smartyon the even numbers (no added timing).
Old Aug 22, 2007 | 03:27 PM
2003Ram's Avatar
Yes, even numbers.
Old Aug 22, 2007 | 05:16 PM
mm73's Avatar
hey not to bother anyone but I have a smarty also and i have been runnin it on 5 and love it but was wondering if if could be stacked with a bd pmt and just keep the smarty on 60hp without timing and then can change the pmt on the fly. I just dont know if it is possible cuz no one really talks about it. Oh and this is my first entry here.
Old Aug 22, 2007 | 05:43 PM
2003Ram's Avatar
PMT?
I have Smarty stacked with Quadzilla. Quadzilla adds timing so I run the even numbers on Smarty and run Quad on 60hp with the adjustabilty to go to 100hp (140hp = no change from 100hp setting so i don't go any higher).
skydiver41
Mar 23, 2012 08:51 AM
stock03
34
Apr 21, 2011 07:40 AM
jmccart
Nov 22, 2007 07:43 PM
Mike Holmen
May 21, 2007 10:21 PM
bnold
39
Jun 4, 2006 08:21 AM
