Smarty Question?
Old May 1, 2007 | 05:04 PM
SJ21XDC's Avatar
Smile Smarty Question?
Well after several months of reading this forum and going back and forth between the XZT & Smarty I decided to call Larry and .................................................. ...................................ordered the Smarty!!! Thanks Larry it was nice talking with you. This is my first performance modification and have a question. I plan on ordering gauges tomorrow and want to know if I don't tow anything or stand on it to hard will I be Ok to play with the Smarty on SW#3 without guages for a couple of days.
Thanks,
Steve
Old May 1, 2007 | 05:14 PM
dodgezilla04's Avatar
I would not run any perfomance module or programmer at all without gauges. I have seen my truck STOCK exceed 1400* when towing heavy up a grade. So with a hot rod programmer, you'll be living on borrowed time. I would wait.
Old May 1, 2007 | 05:20 PM
SJ21XDC's Avatar
That's not what I wanted to hear LOL!! I guess I better get on the ball and get the guages ordered now!
Thanks,
Steve
Old May 1, 2007 | 05:22 PM
get them from lary too.
Old May 1, 2007 | 05:25 PM
P.J's Avatar
P.J
It's nice to have a baseline to work from too. I mean, you will want to know what your readings are in different situations STOCK, this way you can tell what is going on with the Smarty loaded (or any other mods for that matter).
Good luck.
Old May 1, 2007 | 05:31 PM
Luvnacumns's Avatar
C2 on that. Guages are cheap insurance!!
Shane
Old May 1, 2007 | 06:35 PM
StrokeThisCTD's Avatar
I ran around 30k plus modded miles without gauges. Even went to the track a couple times and ran without gauges. I ran an Edge EZ first, level 3 all the time, towing or not went just fine. Ran the BDDL on the 90hp setting for probably 20k of those miles, some towing hard and never looked back. Now i have gauges and found out that my bullydog runs no hotter than stock on the performance setting. (ok maybe 50 degrees at the most)
Old May 1, 2007 | 07:44 PM
KKB's Avatar
KKB
I have run my smarty on #7 since I got it probably around 5000 miles ago and everything is fine, but I don't tow anything and I don't totally abuse it. Well I did beat on it pretty good tonight since I just got my Goerend tranny today so I had to have some fun. Some day I will get gauges, but if you are smart about it and don't tow heavy and use your brains you will be OK.
Old May 1, 2007 | 07:52 PM
white06's Avatar
i have a question about the smarty . what is the difference or is it better on the truck to run with or without the timing ? i am wanting to order the smarty soon .
Old May 1, 2007 | 08:45 PM
JohnInNH's Avatar
If it's not stacked.. (Just the Smarty) then run the with timing.
Old May 1, 2007 | 09:18 PM
white06's Avatar
can the smarty be ran with the edge juced w/attitude ?
Old May 2, 2007 | 08:41 AM
SJ21XDC's Avatar
Thanks everyone. I should have gotten the gauges a couple of weeks ago . If the Smarty gets here Friday the temptation might be more than I can stand! We'll See.
Thanks,
Steve
skydiver41
Mar 23, 2012 08:51 AM
stock03
34
Apr 21, 2011 07:40 AM
jmccart
Nov 22, 2007 07:43 PM
Mike Holmen
May 21, 2007 10:21 PM
bnold
39
Jun 4, 2006 08:21 AM
