Smarty Power on Demand now available in the DTR Store!!
Old Oct 19, 2008 | 08:49 PM
cLAYH's Avatar
Ahh geez! You got me all excited. When you said POD, I thought you came up with a box for on the dash like the Edge J/A, something I could adjust "on the fly".
Sorry but I really don't see myself reaching over, grabbing the Smarty out of the glovebox, fumbling around to plug it into the OBDII port while flying down the highway at 60mph.
It is a great feature for a great product but I really don't see it as having "on the fly" adjustability.
Old Oct 24, 2008 | 09:55 AM
jthorpe's Avatar
DTR Founder
I've been getting a lot of questions about this product via email. If you have a question about it, it's best to post in this thread. That way either Bob or Marco can read them and answer them directly.
Unfortunately, I don't have the answer to the great many questions being asked, so again, please ask them here. For those of you who might not be able to post here, send the question to me and I'll post it for you.
Old Oct 25, 2008 | 12:33 AM
Sthil's Avatar
smarty POD
On the smarty PoD do you have to keep it plugged into the OBDII port and use the console to change the settings or does it have display the sits on the dash; like the edge J/A has. and how easy is it to operate while driving down the road doing 70mph?
___________________________________
2004 Ram 2500 6 speed muffler MIA, turbo baffle removed.
Old Oct 25, 2008 | 12:54 AM
Jason_K's Avatar
it does not use a monitor like the edge j/a. it is the same smarty and you can either leave it plugged in all the time or put in the setting you want and unplug it. when the truck is driven with throttle applied all you have to do is program the PoD level you want (00-99) press and release the throttle twice, the third time you press the throttle the power will be changed. it may sound like a hassle but i assure you that it is very simple.
jason
Old Oct 25, 2008 | 01:44 AM
Sthil's Avatar
while plugged in will the obd plug get in the way?
is it possible to mount the smarty somewhere for ease of access in the case you do decide to leave it plugged in so changes can be made on the fly?
Old Oct 25, 2008 | 02:36 AM
ScotS's Avatar
There was an article in one of the 4wd magazines recently where they talked about various methods for increasing mileage. One of the items reviewed was the Smarty. First mention of the Smarty that I can recall seeing in any of the print mags. Anyway, and unfortunately, they didn't see any increase in mileage but they did see an increase in performance. I was expecting to read about some mpg gains. Thoughts or comments?
Old Oct 25, 2008 | 03:16 AM
Jason_K's Avatar
it does kind of get in the way when pluged into the obdII. all i did was remove the obdII connector from it's mount(under the dash), attach the smarty cable to obdII connector, zip tied them under the dash (and out of the way)and rerouted the cable to other side. the cable is actually long enough to reach the lower compartment of the center arm rest
Old Oct 25, 2008 | 09:53 AM
genros's Avatar
I currently do not have the revo or tnt r downloaded into my smarty yet. I would like to send my smarty back in to get the pod. Would the pod uipgrade effect the download configurations or ability to download new configurations off the mads website at all?
1. Should i get my tnt upgrade before i send the unit back in for the pod upgrade
Old Oct 25, 2008 | 10:24 AM
Totallyrad's Avatar
The programs for the pod are not interchangeable than the standard Smarty programs.
Old Oct 25, 2008 | 04:46 PM
Jason_K's Avatar
no need to download tnt into smarty before you send it in because like totallyrad stated, the tnt download off of mads site is not compatible w/ the PoD. however bob can install the PoD tnt before he ships it back to you. just leave him a note in the box.
Old Oct 26, 2008 | 08:48 PM
SAVOY1964's Avatar
I have a question...I have a 03 without the latest factory update that activates the horn blow while in reverse with door open will installing any of the smarty/pod programs activate this?
Old Nov 21, 2008 | 09:17 AM
Dan_K's Avatar
How about this DTR store find some headlights. I don't want to convert my wiring from stock to HID.
Find some light so as I can see the road and I'll buy.
PM me.
Old Nov 24, 2008 | 12:46 PM
JDL09's Avatar
I heard that a switch can be rig'd up to create the smarty adjustable on the fly without the programmer and I was wondering if this was true, im newly into diesels so dont make fun lol thanks
Old Nov 24, 2008 | 03:09 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
No that is not true, however you can buy the POD smarty which is adjustable on the fly
Old Nov 25, 2008 | 12:51 PM
JDL09's Avatar
Smary Questions
Can a switch be rig'd up to make the smarty adjustable on the fly without using the POD? If so how? and if not how exactly does the POD work? thanks alot for the help.
