Smarty POD/TNT R
Old Oct 2, 2009 | 12:17 PM
genros's Avatar
Smarty POD/TNT R
Guys,
I want to upgrade my Smarty to the POD. Can or will the pod wrk with the TNT-r and other hot programs
Old Oct 2, 2009 | 12:30 PM
molalla1ton's Avatar
Originally Posted by genros
Guys,
POD works with tnt/r.
Old Oct 2, 2009 | 03:20 PM
genros's Avatar
awsome news
thanks
Old Oct 9, 2009 | 02:19 PM
genros's Avatar
SO i got the new pod tnt-r hooked up.
1. In theory, if i set the tune to 9 and the back off with say #60 level is that the same as running say tune 7 on the ecm?
2. Im running a set of twins with twin cp3 and f-1 #4 injectors. Any running similar? what tntr tune do you run ? whats the sweet spot?
Old Oct 13, 2009 | 03:55 PM
zuki_dan's Avatar
I have a setup similar to yours and I normally run on mild or moderate TQ and set to 7 POD between 99-60 depending. Its really presonal preference but I have noticed with my truck if I turn the POD down to far the trans starts stacking shifts quickly and will lug the motor and make it smoke more during DD. DD is the other reason I keep the TQ setting low. Power level 9 seems to be about the same power level as 7 but just brings the fueling and smoke in the lower RPMs.
1985cucv
Mar 10, 2010 09:46 PM
wildcat
Aug 11, 2009 11:22 PM
-PowerWagon-
Dec 30, 2008 01:06 AM
Billwie
Dec 16, 2008 02:09 AM
rallydriver
Nov 1, 2008 12:41 PM
