smarty mp8 stack
Old Jul 14, 2008 | 03:31 PM
homewrecker's Avatar
Originally Posted by Timecode
I just picked up an MP-8 and was wondering where everyone was mounting he Dial. Any pics?
I put mine just to the right of the steering colunm.You can just make out the silver **** in the pic.
Old Jul 14, 2008 | 04:59 PM
rip 112's Avatar
Originally Posted by wap
Not to rain on your parade but on my truck the 4.4 is more than enough pressure without the mp8. I would highly recomend cuttin the mp8 off unless you really need it. But IIRC your truck is not a 610 so it may not be as bad but I can cruse at 20k easy and spike to 27 or more with JUST the 4.4.
When the RP gauge worked it never went past 25k, the highway #s were good and I hardly ever have it set past 50. Its known that the 04.5 up motors ran hgher rp #s even from idle. The 4.4 alone got me to 22k, but very rapidly.
Old Jul 14, 2008 | 05:00 PM
rip 112's Avatar
My **** is to the direct left side of the steering wheel in homewreckers place.
Old Jul 14, 2008 | 06:03 PM
wap's Avatar
wap
Mine looks just like homewreckers and after I posted I got to thinkin you guys had the non 610 motors.
I just wanted to make sure everyone knew that the mp8 with a smarty beta was too much pressure on the 610s.
Old Jul 14, 2008 | 08:08 PM
Asher's Avatar
Sure the smarty can make pressure, if you set it to.. but with just the smarty you can't adjust on the fly like some of us want.. I don't want to have to run my truck around on "kill" all the time... Heck it is very rare that I need more than 50% throttle, but when the need occurs, you can't pull over swap programs and go at it again... this is where the MP-8 shines, roll the **** to your hearts content and when done go back to the regular program after your finished...
I am pretty sure this is why the subject was brought up... I found my truck responds best to smarty on 3, and then juiced up with the MP-8 for those needed moments.. I tried the other smarty programs and really didn't become impressed with the other levels, it seems like to much smoke and now as much throttle response...
The MP-8 really kicks down low (alot more then my EZ did) and I don't have anything against Quad but his box alters the timing a little bit and that would kind of put you all over the place with your smarty, I think you can have the timing taken out, but then you are just winding up with nothing more than something a hair less then what a MP-8 does...
Old Jul 14, 2008 | 11:32 PM
12valve's Avatar
how much does an mp8 increase pressure, say for the 06 in my sig, or is it just too small of a pump, if it goes down to 16000 psi when shifting
Old Jul 22, 2008 | 11:29 AM
35" 05''s Avatar
I cracked my #2 injector runnin 20k for 3 hrs. that = 4 gallons of fuel in my oil in 15 miles. Be careful
Old Jul 23, 2008 | 11:01 PM
ModManiac's Avatar
On they dyno my mp-8 only helped out 40hp but around 140tq. From looking at the graph comparing the run with and without the mp-8 there was no difference up till 1800rpms and then helped smooth out the over all tq and hp curve.
Old Jul 23, 2008 | 11:20 PM
lit up's Avatar
I agree with wap, the 4.4 and MP8 will create to much pressure. I had to replace two injectors because of this stack. It runs great but I think you can get more HP with REVOLUTION alone. I do like stacking the TST with Smarty!
The TST will give some adjustment.
Old Jul 24, 2008 | 09:28 PM
rip 112's Avatar
Keep in mind this is more the case for the 04.5 up motors. They hold considerable more RP than the 03-04s at all times, even idle.
Old Jul 24, 2008 | 09:47 PM
tcr's Avatar
tcr
exactly, our 03-04s IMO were not at the top of Marco's list when the new tunes were developed. I'll put the beta 4.2 w/ psi box against any of todays TNT stuff on an 03-04 engine.......and I'll win........and I'll put my money where my mouth is at this point. As one can tell I'm getting a little bitter on all the problems I've encountered w/ these TNT/R, TNT, and Revo tunes. I have yet to find one that allows my transmission to function properly and I just don't get it Betas 4.4,4.3,4.2,4.10, and good ol' 4.11 all work flawlessly. Ok, I've beat it to death by now..........
Old Jul 29, 2008 | 11:17 PM
ram3qrtton4x422's Avatar
i just got the mp8 but i have to send it back to get the timing off of it. who do i contact to do this? thanks Nick
p.s. i bought it used off a fellow member.
Old Jul 30, 2008 | 06:28 AM
Asher's Avatar
I didn't think the MP-8 was ever available with timing added... You might want to call TS-performance and ask, but you should be good to go like you are...
Old Jul 30, 2008 | 07:24 AM
Hintz's Avatar
Yep, no timing on the MP-8
Old Jul 30, 2008 | 07:24 PM
x2 on the no timing.Go to there TS's site.It says the added pressure has similar effects as added timing, but it does not do timing,pressure and boost fooling only.
http://www.tsperformance.com/
