smarty mp8 stack
Old Jul 13, 2008 | 05:34 PM
blackdieselram's Avatar
smarty mp8 stack
at the moment i have sw3 loaded on my truck for daily driving and was wondering how much hp the mp8 would add for when i wanted to play. i would like to get something that would allow me to be able to adjust on the fly. would a tst be able to add more with its adjustable settings since the smarty is on a low setting? thanks for the help
david
Old Jul 13, 2008 | 05:40 PM
WICKEDDIESELS's Avatar
I am running the Smarty on 9 REVO tune and an MP8 turned all the way up, with small 75 hp injectors. I like it well, the MP8 really helps the low end fueling and the response.
Old Jul 13, 2008 | 05:49 PM
dzlfarmboy's Avatar
We saw about a 70hp gain from just the Smarty and them adding the MP-8 on our 06 truck.
Brett
Old Jul 13, 2008 | 10:02 PM
Asher's Avatar
Well I shouldn't be (no tranny mods), but I am running the smarty on 3, and have a MP-8 stacked... The truck really comes alive when you turn on the MP-8, but just like you want to do I run around with it off- unless I want to kick it in the A$$... You won't regret your purchase...
Old Jul 13, 2008 | 10:30 PM
thanks for the replies. i have been doing some more reading on stacking pressure boxes with the smarty and noticed several people stack the quad x2 with it. is there a lot of difference between the way the mp8 and the x2 adjust the pressure? i dont have a rail pressure guage and the x2 comes with one so maybe that would be a better option?
Old Jul 13, 2008 | 11:20 PM
jmccart's Avatar
Does an MP8 make boost come in earlier?
Old Jul 14, 2008 | 07:57 AM
tcr's Avatar
tcr
Yes, I'm sure it does considering it's mostly if not all pressure.
Off topic, but has anyone used both a Quadzilla pressure box and an MP-8? As much good as I'm hearing about the MP-8 I'm wondering if I should try one in place of my Quad X2 pressure only?
Old Jul 14, 2008 | 08:29 AM
dzlfarmboy's Avatar
The Added pressure does help lite the chargers better.
Brett
Old Jul 14, 2008 | 09:51 AM
rip 112's Avatar
I run 4.4 beta on sw5 with the MP-8 set on 50%. Boost is alot quicker, now it spools just like stock, but the smoke is COAL! It will lay it out even at wot! I am very impressed with this setup.
Tom, don't know about the quad box but I did have the RP gauge fail, so I don't know if I would run them together for fear of the same problems.
Old Jul 14, 2008 | 10:14 AM
matego's Avatar
madhat's monkey boy...
The MP-8 is a nice little kick in the butt with the Smarty. I keep TNT#1 with no pressure loaded and use the MP-8 when the need arises. I would say it makes the power come on about 2-300 RPM sooner by lighting the turbo quicker. I dont like pressure all the time and thats why I like the MP-8. I never ran the quad pressure only box so I cant comment.
Old Jul 14, 2008 | 10:42 AM
wap's Avatar
wap
Not to rain on your parade but on my truck the 4.4 is more than enough pressure without the mp8. I would highly recomend cuttin the mp8 off unless you really need it. But IIRC your truck is not a 610 so it may not be as bad but I can cruse at 20k easy and spike to 27 or more with JUST the 4.4.
Old Jul 14, 2008 | 11:09 AM
35" 05''s Avatar
hey Wap, turn that pressure down....Trust me
Old Jul 14, 2008 | 11:29 AM
wap's Avatar
wap
How so? Take 4.4 off? I am takin 4.4 off, but a friend of mine has my smarty right now. That is the only pressure I run, and yes I have blown a relief vavle.
I am gona load up TNT and use it until I get the TNTR from Bob.
Old Jul 14, 2008 | 11:53 AM
tcr's Avatar
tcr
As you probably know the 03-04s run much lower pressures, even w/ the TNT/R I can't get above 25000psi w/o the Quad box. SO we do need the additional pressure even w/ the new stuff from Smarty/Mads.
Old Jul 14, 2008 | 12:01 PM
Timecode's Avatar
I just picked up an MP-8 and was wondering where everyone was mounting he Dial. Any pics?
