Smarty jr (what is your setting?)
Old Aug 28, 2012 | 09:20 PM
Colbydean4786's Avatar
Just seeing all the different settings everyone is running, feel free to chime in! I'm tryin sw2 tq2 tm2 still have a little slip in 5th gear wanna I hammer down;(
Old Aug 28, 2012 | 09:23 PM
rockcrawler304's Avatar
See sig. I also have the latest update of 5.14B
My clutch slips on SW3 badly and if I go "Easy" on SW2 I can manage it. A new SB clutch is in my very near future!!
Old Aug 30, 2012 | 02:18 PM
cstewart's Avatar
Same...settings are in my sig.
The truck (more importantly the stocker tranny) holds SW2 well, especially if I "roll into" the throttle rather than just stomping on it. My experience has proven that trying to run SW3 is a complete waste of time. With the stock 48RE, the additional power provided by SW3 is a mute point when you can't get anything to the ground!
Hence, complete tranny rebuild is in the "near" future. At that point I plan to run SW3 (same TQ & TM settings) on the reg!
Later...
Old Sep 6, 2012 | 10:05 PM
hot_runner58's Avatar
I am running sw3 tq default and tm 3 POD 99. I drive it nice via the stock tranny, as mentioned previously it will be upgraded soon! but, I have found my best milleage running at this setting so far. got 1.5mpg better than anything I ran in SW2. BUT, every truck is different. In the papers that come in the box, the truck MADS tried the Smarty out on got the best milleage running sw3, pod 60, and the other settings I don't remember.
Old Sep 6, 2012 | 10:31 PM
I also get my best MPG on SW3 but i can't keep my foot out of it and my clutch hates it so to save my wallet some grief I run SW2
Old Sep 8, 2012 | 06:27 PM
hulmule's Avatar
ok ive got a 06 mega cab that is all stock with 45k on it. I want mileage. So my question is you all talk about the settings. Is this Smarty box jr the box to use to get good mileage? there's so many chips out there? Dont know what to buy.
Old Sep 8, 2012 | 06:43 PM
Yes!
The Smarty products are programmers that change the factory settings in the ECM (while keeping the factory settings saved!) to do what the factory should do from the beginning!! Doing a search here for smarty will answer more questions that you knew you even had!!
Old Sep 8, 2012 | 07:30 PM
cstewart's Avatar
hulmule,
To echo my boy Rockcrawler...Yes, the Smarty JR (in my humble opinion) is the answer your looing for with respect to:
fuel economy, driveability, and or "safe" additional power without making any other mods to your truck (outside of gauges...but, I feel that even a stock truck should at least have gauges to monitor EGTs, boost, tranny temps)
In short, unless you are looking for a more aggresive tuner for racing, pulling, etc...I don't think your going to do better than the Smarty Jr from a performance and customer service standpoint.
Good luck with your decision...and "if" you do decide to go with the Jr you will find more than enough support/suggestions here!
Old Sep 9, 2012 | 11:09 PM
Originally Posted by cstewart
hulmule,
as mentioned above, when refrencing pulling, I believe he is talking aggressive pulling, tractor pulls, etc. If i'm wrong chime in. I use the smarty jr for pulling anywhere from 4k-21k behind me and it works great. The chip, if you read around, if tuned right will help keep your egt's down, which of course is good for towing. No complaints on power or egt's on my end with it.
Old Sep 10, 2012 | 12:33 PM
cstewart's Avatar
Yes...my bad. When I mentioned "pulling", I was referring to competition sled pulling and such.
hot_runner is absolutely correct. The Smarty is extremely helpful in keeping EGTs at bay when towing.
Thanks for clarifying!
Old Sep 12, 2012 | 09:34 PM
gsmopar's Avatar
SW3, everything else is at default. I just installed it this evening and drove it around the block. Not too sure what I think about it yet.
Old Sep 18, 2012 | 12:52 PM
RiverRat2's Avatar
Change settings question
My buddy set mine up on SW2 TM2 POD on 65 if I want to go to 3 do I have to go back to stock and reprogram back to SW3 & TM3???? I want to see if the mileage will improve some over the SW2 TM2 settings got a 700 mile pull to Drag boat races this weekend pulling the raceboat...
Old Sep 18, 2012 | 01:06 PM
No.
You can just input the new setting you want and then update it! Just changing the settings will not do anything. make sure it goes through the whole 5 min or so update.
Also, do you have the most up to date software? Should be 5.14B when you first plug in the Smarty. If not, you should update that first. It is a much better version IMO! Just an FYI, you can update that without taking your truck back to stock.
Old Sep 18, 2012 | 11:48 PM
RiverRat2's Avatar
No.
Yeah thanks for the reply he showed me how to do it,, Like you said,,, I had to wait for it to update... I'm Not sure what version the software is Iwill look tomorrow, I gained about 1.3MPG from 14MPG to 15.3MPG hand calculated around town/highway mixed On the Sw2/tq2 settings with POD on 60 driving like a grandpa!!!!
BTW, can I just Plug the Smarty into my laptop and see what software version I'm running???
Old Sep 19, 2012 | 11:28 AM
cstewart's Avatar
Not sure about plugging it in to your computer for this info, but you can easily plug it in to your truck and check the version. Quickly after you plug it in, it will flash the version you are running....this happens only quickly as a "flash" and then rolls to the menu options.
And Yes, I agree, the newest version is much better...smoother/ even power through the throttle, less smoke (not completely gone, but better).
Have a good one..
