Smarty Jr. and G56
Smarty Jr. and G56
I have and 07 with a G56. Will the clutch handle the 100HP setting on the Smarty Jr. if I'm careful how I shift and how I pull out or will it slip? If it does slip and I back off right away will the clutch be ok or will it be ruined instantly?
Thanks
Thanks
I'm running 285's and have a 2000# camper on my back constantly and have used up to #3 without slipping. However,I'm currently down to #1. I just don't have the pesos for an SBC right now or in the near future.
If you know how to use a clutch and don't lug it in high gear then it should be ok. I must have a weird truck but my stock clutch holds my beta 4.4 fine if im redlining every gear. If lug it in high gear and then all of a sudden it spools up, it will slip badly. But as long as you don't do that and constantly cowboy it around it should be fine. My truck has 20,000 miles on it now and the last 11,000 has been on sw#9 or beta 4.4 and it still holds fine. So it should be ok but I can't garuntee anything because every truck and driver is different.
RunningM
Oct 6, 2011 11:34 AM
ridofpwrstroke
Sep 25, 2010 07:32 PM
1993rollincoal
Mar 15, 2009 11:18 PM
Sloverado
13
May 13, 2007 08:18 AM
