Smarty jr Fuel mileage
Old Dec 3, 2007 | 02:29 PM
mad1's Avatar
anyone experience fuel mileage gains with Smarty jr? If so , on what level are running on?
Old Dec 3, 2007 | 05:04 PM
gus's 03's Avatar
i do, i was one of the first beta testers for the jr software. im not going to coment milage wise because im waiting to hear back from bob. i will say it changed conciderably from the previous 4.4 software....
Old Dec 3, 2007 | 05:44 PM
mad1's Avatar
can you at least tell me what level you ran it on with the mileage gain?
Old Dec 3, 2007 | 08:35 PM
jdec's Avatar
Smarty mileage
I just installed mine on Thursday evening and took a trip on Friday. I already got good mpg: about 21 to 21.5 on freeway at 70 plus and 22 and slightly better on 2 lane roads at 60. The first leg of my trip, when I stopped for the night, I filled up and it was a bit over 23 mpg. The total trip with quite a few stops and a little adverse wind netted 22.7. This was driving mostly freeway at 70 plus.
Old Dec 3, 2007 | 09:30 PM
LFD2037's Avatar
jdec, is that overhead or hand calculated? Thx.
Old Dec 3, 2007 | 10:47 PM
jonx15's Avatar
What level did you load up..????
Old Dec 4, 2007 | 10:27 AM
mad1's Avatar
I also would like to know which level was loaded!!
Old Dec 4, 2007 | 10:34 AM
AH64ID's Avatar
I'd like to know as well.
Old Dec 4, 2007 | 10:45 AM
soulezoo's Avatar
DTR 1st Sergeant
I can tell you I saw a 2mpg over stock mileage-- I always hand calc-- from 19 to 21 on my truck. Your results may vary!! I used sw3-- the 100hp file.
Old Dec 4, 2007 | 06:16 PM
jdec's Avatar
Smarty mileage
It is hand calculated. I keep a calculator in the truck and figure every tank. I was running on the 40 hp. economy setting. The air mods and turbo hose helped about the same as Smarty. I am very pleased. When I put my tonneau cover back on and summer fuel is back, I expect to get evern more.
Old Dec 4, 2007 | 06:48 PM
larryt's Avatar
Test Run
Just got my smarty jr today and installed the 'economy' software.
Ran a 140 mi. round trip on intestate with cruise control set at 65.
Temperature was 65 deg and not much wind.
After correcting miles traveled per GPS reading I come up with 23.38 mpg.
I had run the same course on 11/17 stock and came up with 22.86 mpg.
To be meaningful, however, I would need to do a couple more runs
and check how it averages out.
I removed my Rokktech yesterday and I didn't notice any timing rattle
today but I really didn't put it thru the paces, just an economy run.
Thanks Bob, for the prompt shipment, nice little package.
Larry
A little update: 12/6/07
I made a little longer insterstate run today with smarty jr. still on
'economy'. Cruise control set at 65mph.
Ambient temp = 47 -> 49 deg.
Distance traveled = 193.8 mi. (gps reading)
fuel used 8.58 gal.
mpg = 22.59
So although not as good as the first test still a good reading.
But since these readings are within the normal range of 'scatter'
I had previously run as stock then I can't say without doubt
I am getter better mpg with the smarty.
I do feel, however, I have a 'better fed and managed engine'
with no loss in economy, which pleases me.
So thumbs up to Marko for a great product. Looking forward
to trying the beta or the released version of the beta
sometime in the future.
Larry
Old Dec 4, 2007 | 07:53 PM
NB64's Avatar
Has anyone had a chance to tow with it yet? I wonder how it would compare to the quad standard? I have the quad now. I would need some justification to buy the smarty. But I'll tell you this, I WANT ONE....
Old Dec 4, 2007 | 08:45 PM
dieselengineer's Avatar
larryt
Before you removed the Rokktech, did you have a noticeable timing rattle?
Your mileage run with or without the Rokktech?
Old Dec 5, 2007 | 07:12 PM
mad1's Avatar
Soulezoo I have a question about your mileage gain. My truck is all stock 235hp with a cat and your truck has several mods including trans work. My question is would your mileage gain be misleading with all those mods.I have been told that even upgrading the TC I would gain some mpg. Not saying your gain is not accurate but does the mods contribute to make the jr more effective?
Old Dec 5, 2007 | 07:26 PM
larryt's Avatar
smarty jr
Originally Posted by dieselengineer
larryt
Sorry, didn't notice your post until now.
No, never had a timing rattle.
The one a couple weeks ago was with the Rokktech , no smarty.
The last test was without the Rockktech but with the smarty jr on 'economy'.
larry
