Smarty Jr/Dr P Stack
Can anyone help me out with this, What setting should I run my JR on and does the Dr P do timing. What should I run my timing on. Right now the timing is 4 and TM is 2 on 100hp. As well does anyone have the part # 2014, Can you run a toggle switch to this to turn it off when not needed. I am shooting for mpg and wondering if this is going to help.
Yeah, thats where I got this idea. I have a Dr P sitting on my desk and am wanting to try it out. I am not sure which HP tune he was running though. It also says fact or fiction on the front page. Bob can you tell me what I should run my Jr on so I can go out and try it.
My Dr.p has a toggle switch, i ran a wire from the yellow wire coming out of the box to a toggle to the ground. i had my friend help me. I would give them a call though, 1-877-338-7373, hope that helpss
Can ayone tell me how the toggle switch works and how to hook it up. It says in the box you can have the option of off, towing or performance. How is this possible with one yellow wire coming from the unit. Has anyone hooked up the toggle switch option with the stage III. It is not the triple play unit.
It didn't come with a switch so I will go buy a toggle switch. How can this be adjustable when using only 2 wires. I know you can hook the ground on and the yellow to a 2 pole toggle switch. With that configuration you would have off/on. Does the yellow wire on the Dr.P work off of ground. Right now nothing is hooked up to the yellow and it is full out. When I hook up the ground it must cut back on the power. I can't get a hold of Dr Performance. I thought a person can buy a switch. I checked for install videos but they are pretty vague on how to install that and don't go into how it works and adjustability option. Can anyone that has done this tell me what I need and where to hook the wires.
The toggle switch is most likely a 3-position with one contact to ground and one to a resister to ground and the other open. This would give a simple variable to a current input, this is how a pot could work on the same input.
Just a thought.
Just a thought.
I got it sorted out. I need a 2 pole toggle switch. On/Off is all that is required for the #2014. Thanks for all the help. This thing rocks stacked that is why I need to shut her down for certain driving conditions. Thanks for all the help guys.
