Smarty Jr
Old Jul 10, 2010 | 01:09 AM
Ghamilton's Avatar
Smarty Jr
I had some extra cash that was burning a hole in pocket, got caught up in the moment reading about the Smarty and bought a Jr. I don't have gauges (yes, I know I should) am wondering if I should have waited? I baby the truck all the time and don't tow but wanted a little more giddy up for the occasional romp on the throttle. Anything to worry about?
Old Jul 10, 2010 | 02:23 AM
EDR's Avatar
EDR
I ran my truck with the Smarty Sr. for the first 3 months without issue, but like you I babied it. Since I installed gauges I've run both the Smarty Sr. and then later a Jr. that I traded another member for.
As far as exhaust gas temperatures, if you continue to baby the truck and when towing, put it into the tow/haul mode or lock out overdrive going up into the hills and mountains you should be okay. The only issue I noticed was while running up longer grades towing even a light load (>1000 lbs) in high gear, my truck seems to run fine, but the exhaust temps can really start climbing. I imagine it may even happen while running the stock program, but I've never tested it to find out.
Good luck and enjoy the Smarty!
Old Jul 10, 2010 | 07:02 AM
crowbar's Avatar
Smarty JR
Run in the tow mode it adds about 70hp and shouldn't be a problem.I have run mind for about six mths and seems to do what it says it will do.Just take it easy and have fun
Old Jul 10, 2010 | 10:19 AM
.boB's Avatar
I have gauges, and use the Jr. I had it on 3 for a while, just to see what it does. I'v never seen the gauges go out of range. That should only happen if you're putting a lot of strain on the engine(heavy towing, racing), or something breaks. As long as the truck is in good condition, and you're not beating on it, the gauges can wait.
Old Jul 10, 2010 | 10:37 AM
Ghamilton's Avatar
Thanks guys! The truck is my baby with only 18,000 miles on it. I want it to last but I want to have a little fun too.
Anyone have any input on the Edge Insight with EGT probe for gauges setup?
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
