Smarty and Insight now engine overboost code
Old Apr 30, 2010 | 08:08 PM
no_6_oh_no's Avatar
Originally Posted by J-man
So, you can clamp the hose on yours and you don't get a code or anything?
Yep. Even if you get a code it doesn't defuel. Smarty will remap the boost tables to the limit of the MAP and all your doing is making sure the WG doesn't open.
Old Apr 30, 2010 | 08:54 PM
J-man's Avatar
Well, I guess I'll have to try the wastegate off option on the Smarty again and see if it works. Hope so, because I hate watching those boost numbers go up, up, up, and then all the sudden back down when your still givin er fuel!
Old Apr 30, 2010 | 09:14 PM
qzilla's Avatar
The insight is not going to rad boost correctly if you use the Smarty with the boost fooling software as it semi "fools" the ecu into thinking it is at a different boost level. the Insight reads off the data bus so it is spitting out "fooled" data.
Second, you need a real boost fooler.
Old Apr 30, 2010 | 10:07 PM
J-man's Avatar
Yeah, I may have to get one some day. I was used to the edge juice which did it's own boost fooling.
Diggie
Mar 23, 2008 08:50 AM
O.T
Sep 6, 2007 06:10 PM
RyeThomas
Jun 14, 2007 09:05 AM
SSV1761982
Jan 29, 2006 03:32 PM
kcbarnes
May 4, 2004 11:08 AM
