smarty and freeze plugs
Old Jan 16, 2008 | 10:35 AM
  #46
XLR8R's Avatar
Originally Posted by UnrulyNFS
Knock on wood, I been lucky so far. I don't reckon that BOE would fit on a twin turbo setup would it?
Sure it would, Keegan! Between clocking the fittings and adjusting the hose lengths, it'll fit any CTD... change a few fittings and it'll fit any engine.
Originally Posted by cquestad
RAM air is ideal...
I wish I could make a 6" Scotty type air can for my twins...that thing worked the best of any intake I have ever used.
Our cowl induction is designed to work with stock 3rd Gen hoods - see the small photo on the right of the page.
Originally Posted by PEAKSTRYDE
Possibly, but the root of the problem is not the speed that the water pump turns. As stated before the problem occurs when the T-Stats are closed, therefore no water is being circulated through the block.
The excessivly quick heat build-up, which comes from more/higher RPM is when the problem arises.
Again, excessive water jacket pressure can occur with the thermostat open OR closed...
Old Jan 16, 2008 | 11:12 AM
  #47
cquestad's Avatar
Sorry...I have a turbo in that location!
RyeThomas
34
Oct 13, 2008 10:47 AM
Lyall
Sep 7, 2006 06:38 AM
Cummins600
May 8, 2005 09:53 PM
shemp47
Nov 15, 2004 11:06 PM
Duke1234
14
Feb 4, 2004 07:15 PM
