which smarty
Old Aug 20, 2009 | 05:27 PM
jclay84's Avatar
which smarty
which smarty do i get whats the difference in the to
Old Aug 20, 2009 | 05:29 PM
rip 112's Avatar
Its best you look at this yourself and decide how much power you want...
Smarty JR
http://www.madselectronics.com/SmartyJR.html
Smarty SR
http://www.madselectronics.com/Smarty06.html
Old Aug 20, 2009 | 05:41 PM
madhat's Avatar
Administrator/Jarhead
Well, you can get the smarty jr, smarty S06, or the smarty S06 PoD.
The links up there describes the two well, the Pod gives you adjustability on the fly, power levels from 1% to 100% of any given software.
http://www.madselectronics.com/Smarty06PoD.html
Old Aug 20, 2009 | 07:30 PM
jclay84's Avatar
so the difference between the so6 pod and the so6 is the switch on the fly
Old Aug 20, 2009 | 07:44 PM
trik396's Avatar
I just installed Smarty Jr. in my truck ten minutes ago. Running the performance with 2 and 4 for torque and timing. I think this is the most power for the Jr. but I may be mistaken. Initial judgements are pretty good power. Smooth. No rattle that I heard. Some smoke with aggressive take offs (not full throttle). Not bad at all. And I adjusted for tire size for the first time on my truck which is one of the reasons I got the smarty. Running stock turbo currently. Have to change my sig.
Old Aug 20, 2009 | 08:20 PM
madhat's Avatar
This is correct.
You can only run one software (SW1-SW9), but you can control the percentage of that software on the fly.
Old Aug 20, 2009 | 08:44 PM
quadman20's Avatar
If all your going to do is have a stock truck with maybe some simple mods then Jr but if your ever contiplating more agrressive mods and racing,sled pulling then go S06pod
Old Aug 21, 2009 | 06:12 PM
jclay84's Avatar
im going from a quadzilla to smarty and i want to do the tranny so i should go with the so6 i think whats the different tunes you can put on them
Old Aug 21, 2009 | 09:47 PM
thebestofindica's Avatar
To me the POD isn't worth anything. Get the jr if you just want some more snap in the go pedal without tearing things up.
Old Aug 22, 2009 | 07:10 AM
1985cucv's Avatar
i disagree buy the s06 you wont regret it.
Old Aug 22, 2009 | 07:36 AM
nofatum's Avatar
If you play, you got to be ready to pay. I went with the Jr. as I know if I had more settings...I would try them.
Old Aug 22, 2009 | 09:50 AM
rip 112's Avatar
I'm pretty sure the S06 is the ticket for you, especially seeing that you intend to rebuild the tranny and do some modding. The S06 will give you the most tuning capabilities and more power levels to use. Just keep in mind what everyone is saying, wear and tear can and will occur quicker the harder you run your truck.
stock03
Apr 2, 2010 12:57 AM
sCreamin400
14
Oct 28, 2009 05:46 PM
Bradleysram
19
May 12, 2009 08:36 AM
UnrulyNFS
14
Aug 3, 2007 11:13 PM
bnold
39
Jun 4, 2006 08:21 AM
