Smarty +230 HP
Wow, I wonder how that 230HP was made? Some pressure added or did you guys get past the extra injection event that the 04.5+ guys have? You should start a trade-in program for people like me with the TripleDog and a 305/555 engine! Actually, just for me would be OK, too
Good job!
Andy
Good job!Andy
If you have the 305/555 engine you will throw your BD as far as your arm is capable as soon as you try a Smarty.
and need more fuel! It's a "competitive upgrade", you know, like trading in a Ford to get a Dodge. Can't blame a guy for trying!Andy
I was in your same boat.
First I was stock and then added a smarty, and then found a killer deal on a silverbullet and installed it.
Well I was a little dissapointed with the performance. I was expecting more out of a SB and smarty.
I was told I needed more fuel (pressure) so I added a MP8 and WOW!!!!! It sure delivered.
Before my truck was kinda slow on the top end now it flat out hauls but. 75mph-105mph in 5 seconds!!!!! Thank you mp8.
Ive heard that the mp8 is still the best at adding pressure, better then adding pressure via TST, Beta, EZ, puck.
They are really cheap used and will wake you truck up ALOT.
I dont have many mods and use my mp8 when I feel the need, even on max if im playing around.
2 years and still no problems or hicups on my Smarty/mp8/silverbullet combo and make's great power.
I still have a stock clutch so im at my limit as far as power goes but still laied down 440hp and 908tq. Not bad for a stock 03 w/ my mods, not even a walbro
I used to run an EZ and it made as much power as the BDTD, easily. But the EZ made the idle goofy on the truck and once in a while it would die pulling up to a stop when releasing the clutch. The Quad module I have no works much better in that respect but I can still tell it's on there at idle. The EZ made it lope at idle like a gasser with a big cam!
Andy
Andy
