Smarty
Old May 20, 2007 | 11:45 AM
chrigu's Avatar
Smarty
hi guys
i can load smarty with aftermarket turbo or injector software on stock turbo ore injector?
chris
Old May 20, 2007 | 11:48 AM
chrigu's Avatar
and wath is the best injector for 2003 ram?
Old May 20, 2007 | 02:34 PM
Robert P's Avatar
you can load the program but you will kill the stock turbo. with the aftermarket injector program you may have less timing rattle though. i ran the aftermarket program for a week before installing my new turbo and it was very easy to get more that 55psi out of the stock turbo. that is a very bad thing. (for the turbo)
Old May 20, 2007 | 02:40 PM
chrigu's Avatar
thanks
i have with smarty on #7 35 psi boost.
another question: you have wat for injector?
chris
Old May 20, 2007 | 04:34 PM
MikeyB's Avatar
Checkout Formula One Flux injectors for our trucks.
http://www.f1diesel.com/injectorsecho.html
MikeyB
Old May 21, 2007 | 10:05 AM
jrussell's Avatar
55+psi out of the stocker with just a Smarty?!?!?
I can't get more than 42psi out of mine with the Smarty aftermarket turbo program on #7.
Old May 21, 2007 | 11:54 AM
chrigu's Avatar
hi
you have stock turbo?
witch programm?
wild torque?
chris
Old May 21, 2007 | 12:09 PM
jrussell's Avatar
Originally Posted by chrigu
hi
witch programm?
wild torque?
chris
I have the stock turbo. Not sure of the exact filename, but I use the standard mild torque management program for aftermarket turbo and stock injectors.
EDIT: I'm also at 4,000+ feet of elevation so that probably affects my boost numbers.
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
