skyjacker leveling kit ?
Is this a good kit to level my truck?
Its the one halfway down the page, the skyjacker 2.5" kit with rear add-a-leafs.
Part#- D2513K
http://www.rockymountainsusp.com/dodge4_03diesel.htm
Part#- D2513K
Guest
Posts: n/a
I went with the springs only. Many around here prefer the Kore springs. I have had no trouble with the Superlift product.
Personally, I would not want add a leafs in the rear.....mine's rough enough as it is. Plenty of room to clear 35's in stock form.
I would want the aftermarket lower control arms though. After adding the D25 springs my tires cycle back to just contact the trailing edge of the passenger fender at full compression, not enough to cause any damage, just make noise. Extended control arms would address that. I'm going to add some to my set up. Probably these unless someone has a source for the Skyjacker version.
http://www.dtprofab.com/dodge.htm
winfield
May 9, 2008 08:57 PM
Superduty12v
Oct 29, 2004 08:45 PM
CumminFast
Jan 31, 2003 04:47 PM
