Silver bullet question...
Old Dec 2, 2007 | 09:17 PM
jwb600's Avatar
it may some lag over your stock turbo but you can add more fuel to get rid of that. should run pretty good with the setup you have
Old Dec 3, 2007 | 08:24 AM
defleshed's Avatar
the resitor or the stock peice will both keep the code from being thrown, you just need something plugged into the harness so the ecm doesn't see an open circuit, the resistor sends back a valid voltage, and so does the stock sensor. the boost fooler or module with boost fooling is what keeps over boost codes from occuring because it makes the ecm see less boost then actual
powerrammaster
May 8, 2009 09:09 PM
Rpainter
Sep 14, 2008 10:39 PM
texhand
Feb 9, 2008 07:56 AM
Rollincoal
Apr 14, 2006 11:22 AM
