big injectors and a silver bullet question
Old Sep 14, 2008 | 01:29 PM
Rpainter's Avatar
what is the biggest injector I can run with a silver bullet? I am wanting twins later but want to get injectors done during the winter. I am currently running flux 3.5 and at 75 mph I see 750 on egt and at wot I see 1350 with water full on and 26.5k of rail pressure. Rob
Old Sep 14, 2008 | 02:08 PM
tatkins85's Avatar
hey robert i dont know how big the flux 3.5's are but im running nozzles from darkside and they are raited at 180hp. i dont know how he rates them but im pushing the limit with the silver bullet. lots of smoke cant even run any programmer on any settings. i have the smarty but dont have it uploaded or it smokes to bad and egt's get a little hot. pulling a trailer with no water with my injectors would probably push it to the limit on the egt side of it regular driving i see about 800 and giving any throttle it gets to 12-1300 till the silver bullet gets some boost going then it cools it down a bit. but i would say what ever my size is i wouldnt want to go any higher. you might be able to contact bobby from darkside to see what his 180hp injectos flow rate is.
Old Sep 14, 2008 | 03:25 PM
Rpainter's Avatar
flux 3.5 are close to 175 hp and I tow nothing. I get smoke at idle and driving with no programmer on. I am at maybe 1,000 on the egt with the bullet spools. no remember my water is direct injection for each cylinder and my motor has been decompressd so I think I would be able to cool better and run more fuel than say stock motor with two water nozzles in the intake horn Rob
Old Sep 14, 2008 | 04:59 PM
bluechrome's Avatar
I'd try Flux 4's But that's about it. Flux 4's fuel hard!!!
Old Sep 14, 2008 | 05:29 PM
tatkins85's Avatar
If you don’t tow anything rob I would just go with the flux 4's then you can always learn to drive different to keep the egt's down and worst case scenario you will get your twins sooner :P
Old Sep 14, 2008 | 06:05 PM
Don M's Avatar
DTR Advertiser
The low compression is causing the idle smoke. You should be able to run a 4.5 or 5 on a single turbo with the 03-04 engine for more power. Of course the idle smoke will just get worse.
Old Sep 14, 2008 | 06:30 PM
Rpainter's Avatar
don what about my 04.5 motor? smoke does not bother me in the last 6 weeks I have put awhole 325 miles on the truck so I drive it a lot. Rob
Old Sep 14, 2008 | 06:40 PM
Don M's Avatar
DTR Advertiser
I was thinking you had a 03-04, but was using my memory VS reading your sig line. A 4 is about it, but it should be very competitive with a 3.5 already.
I am working on a new design now for big power guys. Wanna try some?
Old Sep 14, 2008 | 06:47 PM
Rpainter's Avatar
SURE.............
Old Sep 14, 2008 | 06:48 PM
Don M's Avatar
DTR Advertiser
Send me your stix and I will make you some up. I have about 10 sets out there now. Results are great.
Old Sep 14, 2008 | 06:54 PM
Rpainter's Avatar
are they bigger than the ones I have or just a different spray design Rob
Old Sep 14, 2008 | 08:10 PM
bluechrome's Avatar
I'm also intersted Don
Old Sep 14, 2008 | 10:39 PM
tatkins85's Avatar
lol me also Don
powerrammaster
May 8, 2009 09:09 PM
Billm2004
16
Dec 3, 2007 08:24 AM
OldSmokey
16
Nov 26, 2007 09:44 PM
dodgecowboy04.5
Aug 7, 2007 02:34 AM
