Should I put TNT on my buddys truck?
Buddy has an early 04 Cummins with lots of goodies and low miles (26,000)
Aftermarket intercooler
Industrial Injection 62/14 turbo with boost around 40 psi
ATS exhaust manifold
60 hp injectors
afe air intake
banks air horn
air dog lift pump
5" exhaust
Smarty
I thought I was going to be able to put POD on it but you can't, so I'm wondering if TNT would be worth trying.
He doesn't really tow hardly ever and pretty much just hot rods it everywere.
What software would you guys recommend?
Does TNT raise your shift points and rev limiter? Or is that TNT/R?
Elevation is around 5k if that matters.
I told him his next upgrade is probably a CP3 but what do you guys think?
This truck has the stock auto and I think he is waiting for it to blow up because his wife doesn't want him to spend that much money on something that isn't broken. However, if it breaks it has to get fixed
Perhaps TNT will assist with this?
He blew up the turbo and that is how he got the Phat Shaft and intercooler
What are the hp gains on what power levels with the 03-04 trucks?
Thanks for the help
60 hp injectors
afe air intake
banks air horn
air dog lift pump
5" exhaust
Smarty
Thanks for the help
Why wont POD load on his?? POD isnt a power version. Meaning if you have the Revo, then the Revo POD, you wont gain anything over the regular Revo w/ the POD version. POD is simply the ability to change the effect of the SW. Basically changing power on the fly. 99 has full effect of, say, SW#9. 60 is obviously less of an effect, but still is SW#9 loaded...
Some guys are getting a rail pop on the earlier trucks with TNT. I got a little bit on the 03, but apparently didnt hurt power, as I happened to get into it w/ an automatic 05 w/ Bullydog and beat him pretty good. Try TNT and see if he gets the popping
With the injectors he doesn't really have the fuel system to run much. TNT 1 or 3 will probably drain the rail.
Needs a lift pump and a CP3 upgrade for sure.
And the POD won't load because he needs to send the Smarty to Bob to get the firmware updates.
pulltilbroke
Sep 2, 2011 12:07 AM
TORQUE BEAST
13
May 9, 2008 02:31 PM
Dwitt0187
May 8, 2008 03:47 PM
molalla1ton
Apr 16, 2008 01:08 PM
The TNT will take out the trans quick............if that is his goal do it.
