SHORT Rear Lift Blocks (1-2")
OK, I've tried searching and can't find anything so I'm gonna break this off of the 3" front spacer thread. I just ordered a 2" leveling kit for the front, but I think I want to do a small block in the rear as well, to make sure I'm not sky-pointing while towing. 1" - 1.5" would be ideal, and 2" would be OK. The problem is, every set I've seen is for 2.5" wide springs. These 3rd Gens have 3" wide springs. So, anyone have a good source for short blocks? Jackit.com has blocks for 3rd Gens, but in 4" which is too darn tall.
Not really looking for a full kit, just some blocks and u-bolts. Will the kit for a '00 2500/3500 work? The blocks are only 2.5" wide, but I'm also concerned that the u-bolts for the kit are only 3.5" instead of the 4" that I need.
Yup, I guess I'm gonna have to make some phone calls. TopGunCustomz doesn't have any 1-2" blocks listed, but they might make some and I just need to call. I was just hoping JCWhitney had something because I am making an order anyway and the cost of them will let me use my $30 off coupon!
4x4not let us know what you find out! I got my leveling kit and shocks waiting to be installed, along with tires on order. Does raising the rear cause any vibrations? Are any angled shims supposed to be used? I had a leveling kit on my old truck, but would also like to raise the rear a little on this one. Keep us posted 4x4not!
Thanks,
Nick
Thanks,
Nick
here's what i did.
i bought a 2 in block kit from superlift. it comes with the 4 inch lift kit, but u can buy it seperately. the part number is 4125. it comes with u-bolts for the hemi rear end(3.5" tubes) and the diesel rear end(4" axles tubes)
since i wanted only a 1" or so lift, i removed 2 of the factory shimes and added the 2 in block. each shime is 3/8" thick so removing 2 yields a 1 1/4" in lift.
hope this helps
hope this helps
checkster
Oct 27, 2009 07:24 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Katmandu
Jan 16, 2006 08:30 AM
