shaving calipers ? safe ?
Old Dec 19, 2006 | 12:57 PM
  #31
XLR8R's Avatar
Not a significant factor at all unless you happened to remove the cooling fins that the calipers don't have....
Old Dec 19, 2006 | 12:59 PM
  #32
pooperscooper's Avatar
Originally Posted by Hillbilly Delux
i would think that the extra iron that you would be grinding off would take away some of the heat dicipation, as in not drawing heat away from the pistons and center of the caliper as well, less metal heats up quicker which is bad for brakes, just a guess, dont hold me to it
That is another valid point. Maybe the close proximity of the wheel will do some cool heat transfer stuff. Probably wont be as big of deal as the structural integraty of the caliper
Old Dec 19, 2006 | 04:23 PM
  #33
JHardwick's Avatar
Originally Posted by XLR8R
Well, if they're not cast iron, they're forged... a much stronger method of forming.
If the stress is not tensile (which part of the caliper's cross section does indeed experience), then it's a compressive load - which carries even higher psi ratings.
Thanks for helping to make my point.
p.s. the material hypothetically removed is not in a critical stress area of the casting/forging.
I can assure you that they don't spend the money to forge a brake caliper. it's either cast steel or cast iron. I'm on the road right now, but my money is on cast iron. Cast anything is weaker than billet or forged.
I don't see tensile (pulling) or compression (squeezing) near as much of a problem as bursting from grinding the wall too thin in the area of the piston bore ............. which is bending.
Old Dec 19, 2006 | 04:36 PM
  #34
JHardwick's Avatar
Originally Posted by pooperscooper
Bending is essentially tensile on the top and compression on the bottom or vice versa. in this case it will be compression on the top and tension on the bottom. While most of the force will be this bending, due to the moment being at the top (near the center) and sweeping to the midline as it moves out, the moment becomes less critcal. near the leading edge, there will be a torsional force that will be perpindicular to the moment. Blah blah blah
I mostly agree with this statement. I don't really see how a torsional load applies though. While there are tension and compression loads involved in bending, the bending force is magnified in both tension and compression.
The compression in the area that you are talking about ........... is, well missing, been ground away.
Old Dec 19, 2006 | 09:45 PM
  #35
XLR8R's Avatar
J - I appreciate your tenacity, but in all honesty I must say that you don't seem to be very well versed in engineering principles, industry practices or materials science.
Old Dec 20, 2006 | 01:39 AM
  #36
JHardwick's Avatar
LOL, your too funny
BTW, how many steel extrusions have you seen lately .............. just looking back at a couple recent posts
Old Dec 20, 2006 | 01:31 PM
  #37
The torsional it applies but is not as much of a factor, but still a factor when considering removing material. The pistons will cause the bending, The rotating of the rotor, and the caliper counteracting it will cause the torsion. So you will get a stress concentration at a paticular point where the stresses meet.
The compression area is indeed being ground away, but there is also a layer underneath that.
I would say, get a caliper from the junkyard, grind it down to your specs and hook up a porta power with a gauge and find out at what pressure it blows up at. What is better than engineering something.....finding a model and testing it till it fails!!!
Old Dec 20, 2006 | 02:20 PM
  #38
HappyGA's Avatar
I am willing to bet that on most, prolly all american made DOT vehicles, the brake calipers are made of cast iron. I worked in a foundry in South GA, and we made a lot of brake calipers for different vehicles. We produced the Differential for the Hummer also. All we did was cast iron with x amount of alloys depending on the request from the company. I was in metrology lab(tolerancing lab), but I went to the metalurgy lab often to kill time, and they were always adding this and that to try and keep the iron mixture the same content..
Old Dec 20, 2006 | 03:34 PM
  #39
JHardwick's Avatar
It'd be easy enough to drag a file across it, that'd tell the tale. I may do that when I get home, but my money is still on cast iron. Probably nothing but class 40 gray iron ......... run of the mill stuff. It'll have a high yield point, but a very elogation. I closed my machine shop almost 2 years ago, LOL, I could dust off some of my old books when I get home, hehe.
Old Dec 20, 2006 | 03:39 PM
  #40
JHardwick's Avatar
Well, I have to admit, I never even took the rotational force of the rotor into consideration.
Yeehaw, backyard engineering ......... that's what makes MythBusters such a good show.
Old Dec 22, 2006 | 05:39 PM
  #41
JHardwick's Avatar
Don't forget any decent steel alloy whether cast, extruded or forged, is going to have tensile strengths at least an order of magnitude higher than what the hydraulic pressure can be.
Hydraulic line pressure has nothing (zero) to do with piston pressures. Line pressure is measured in PSI and a piston has several square inches. Take the 800psi accepted line pressure and a 6" piston ............ that takes you WAY off the charts @ 22,619#.
Tensile stregths are only good for comparative numbers in a test lab. If you grind the the stongest steel made thin enough ........... it'll break. Steel with 80,000# tensile strength may hold 800,000# or 8# depending on the application.
I think we have all agreed that a hand grinder may not make a perfect match with an OEM caliper for real world dependability and safety.
But, I'd still like to have an example of a steel extrusion.
I know that I'm lacking in knowledge and abilities when it comes to manufacturing.............
so I'm looking to expand my knowledge.
Old Dec 22, 2006 | 07:55 PM
  #42
Asher's Avatar
Well if they fit on your 05 and not your 06, then why not try to fit on a pair of 05 calipers on your 06 truck, and save the questionable grinding??? and one last
Jeepin951
Apr 5, 2006 05:14 PM
PeytonMaterne
Mar 11, 2006 08:13 PM
darrenG
Oct 20, 2005 04:11 PM
richardg40
17
Apr 7, 2005 08:54 AM
Hawkeye 04
Oct 10, 2004 12:18 AM
