SBC Sprung Hub DD review
Same here. If your gonna do it, go all out. But I love my clutch. And when I've finished destroying this one, I'll then upgrade to the 3850.
torsional springs around a clutch disk hub, are not at all for noise. They are to cushion engagement torque transfer. The hub is only attached to the disk through the springs........so if you dump the clutch or have loaded launches...you're less likely to tear the hub out of the disk. because all engine power transfers through the springs from the clutch disk to the hub. hub and disk are 2 separate peices attached by the springs. thats how it works........
on that note I've got a 3600 DD 6CB and 1 3/8" input upgrade coming..........
O.T
07-07-2007 07:05 AM
D.Wiggs
17
02-18-2007 06:53 PM
