same boost
same boost
ok stock it will throw 34psi crazy larry it will throw 36-38psi i have boost fooler and i tried messing with the boost elbow on my turbo and nothing turn it out no change turn it in no change is there something stuck open like the wastegate or a boost leak maybe i know i throws more than that because when i first put the turbo and crazy larry on it hit 45psi need some advice thanks chad
yes,yes,and no but i do have a fass and hopefully it is pushing enough normally it blows a big puff of smoke and then clears but now it blows a big puff of smoke and then does not clear out and i dont know why its the same setup as before just that i did the diy cp3 mod
but it runs good just not as much boost as i thought would the cp3 mod still run good if it was messed up and not build as much boost im think im getting enough fuel cause it can and will smoke like a freight train
Maybe you can do a pressure test by removing the air intake all the way to the turbo, fab up something to enclose the intake of the turbo (3.5" or whatever it is) hose and same sized pipe with endcap and a schrader valve so you can pump around 40psi of air pressure and see if it holds. If it doesn't you should be able to chase down the leak with some soapy water sprayed on the tubing, hoses, intercooler,etc.
Keep me informed as to what you find out... I guess I'm the only one responding to you in this thread....
I have the stock plastic intercooler sitting in my garage. I'd give it to you but shipping is probably more than what the thing is worth...
J Lent
60
Nov 3, 2009 09:14 PM
jmccart
Jan 18, 2007 03:26 PM
