Rpm's
Old Jul 18, 2009 | 10:36 PM
terl00's Avatar
Rpm's
I just bought a 03 ctd from my dad which he owned since new, it has 85k on it now, ,,, the rpms do not fall fast enough for me, its been like this since it was new,, when i get it above 2 grand it falls slow.. My past 04 and 06 fell great,,, is there anything i can do to fix this???????
Old Jul 19, 2009 | 10:18 AM
puffsmokeonya's Avatar
you may have to explain with more detail.
Old Jul 19, 2009 | 02:27 PM
terl00's Avatar
The rpms fall back real slow in between shifts especially when it get over 23 grand it falls very slow and you have to wait on it, so you can make the next shift
Old Jul 19, 2009 | 09:07 PM
JFlory's Avatar
If it is hanging rpm's that bad it is most likly injectors. Anyone with a starscan should be able to diagnose the problem, or having an injector bypass test done. I have seen trucks do what you are describing and it was always injector related.
Old Jul 20, 2009 | 06:32 AM
terl00's Avatar
Been like that since it was brand new. I would like to see the rpms fall faster between shifts, like my past 04, 06, or even my 02...
Old Jul 20, 2009 | 07:07 AM
MikeyB's Avatar
Tends to be a normal trait with the manual CR engines. Mine does it, seems to be less noticeable with the Smarty though.
MikeyB
Old Jul 20, 2009 | 08:47 AM
sallyman1's Avatar
bad injectors. get off the computer and get it fixed fast. i had a bad one do that and it stuck open while i passed someone and it melted a piston
Old Jul 20, 2009 | 10:14 AM
terl00's Avatar
Well, it has been like this since it was brand new, it has 85000k on it now- don't ya think something would have went wrong with it by now!!!! It runs better everyday i drive it, and gets 20-24 mpg...
Old Jul 20, 2009 | 11:45 AM
rip 112's Avatar
Its normal, its pressure bleeding off from the rail from the high pressure fuel.
jefjsak
Jan 15, 2015 03:44 PM
53 willys
31
Jan 31, 2008 02:24 PM
skeeter
Jan 18, 2006 03:17 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
