Roller's Were Hit!!!
Old May 17, 2008 | 05:05 PM
BossHogg's Avatar
Well after all this time I finally hit the rollers. Although, I didn't get TQ #'s, as I got my truck dyno'd on a dynojet at Jotech. Jotech is an import shop, so they didnt have the a place to tap into.
Anyhow
Smarty 4.4lvl 9 /Quad X2 Race Stack = 484.7rwhp!!! My goal was 500hp, but I realistically went in with a guess of 468hp....I beat that!
Old May 17, 2008 | 05:15 PM
Pooter's Avatar
Nice numbers, but it should do better with a optical sensor equipped dyno,to read the rpms correctly...
I know HPP(Lewisville) has one, not sure if SpeedTek in Ft worth has one(off Carson)
Old May 17, 2008 | 05:21 PM
BossHogg's Avatar
Well are you talking better HP number or just being able to read the TQ? I was told the optical sensor was mainly for TQ?
Old May 17, 2008 | 05:23 PM
BossHogg's Avatar
I am glad to be in the hunt for 500hp though! Awesome!
Old May 17, 2008 | 05:25 PM
Pooter's Avatar
Little of both, youll have a more accurate reading, and I like to know torque numbers, even though HP is what matters
With that combo I would think you should be a little over 500, do you still have stock injectors?
Old May 17, 2008 | 06:05 PM
Bswope's Avatar
I just did 488/966 with the modds in my sig!!
Congrats on the #'s and id say 500 wont be a problem for ya!!!!!
Old May 17, 2008 | 06:31 PM
mopardamo's Avatar
Hello,
Horsepower is not directly measured. It is calculated from torque and rpm. They should be able to provide torque numbers. Maybe they do not have the software set up properly to provide the torque numbers, a conversion is needed for them since it's an inertia type dyno.
Damon
Old May 17, 2008 | 06:43 PM
omaharam's Avatar
Just get it on a load dyno. No sensors to deal with and you'll probably see 520/1150.
Old May 17, 2008 | 06:58 PM
Patriot2500's Avatar
Congrats on the numbers!
Old May 18, 2008 | 03:32 AM
JJPage's Avatar
Turn your Quad box down, You will get better #s.
When I first started Dynoing Smarty, I tended to leave my TST "high".
Increase the Quad 1 increment at a time, while stacked with Smarty, you will break 500.
Old May 19, 2008 | 08:47 AM
BossHogg's Avatar
I actually did hit better numbers with the Quad installed, much better..and its definately much faster by SOTP feel!
I did find out from talking with one of my friends who works at Quad that I ran the dyno test wrong. The shop I took it too was not a diesel shop, and the truck was run in 3rd gear with tow/haul on. I was told that I needed to run it in fourth and to load up the turbo by the use of the break for an accurate reading. Im probably going to give it another run sometime when I find a dyno with the correct tools!
He said I should be in the 520-530hp range....do you guys think he's right?
Old May 19, 2008 | 09:35 AM
BossHogg's Avatar
Any additional dyno tips would be appreciated!
Old May 19, 2008 | 09:36 AM
tcr's Avatar
tcr
You will be right at 500+/-, you will see better #s with the 4.3 or even the 4.2, if you don't like the touchy throttle put the 4.3 on level 1 and the Quad X2 on 3(pressure only). This combo also kicks **** on the 4.2(my favorite)
Old May 19, 2008 | 09:38 AM
staarma's Avatar
The way a Dynojet dyno works is HP is actually measured and TQ is calculated. But you need RPM to calculate TQ using HP. The numbers will not be more accurate with or without RPM. The way it is measured is by spinning the big drums (weight) a certain distance (circumference of the drums) in a certain amount of time (time is provided by the vehicle). It's very simple really and cannot be screwed up.
Nice numbers. If you could provide a graph of HP over speed then I could calculate what your TQ would be.
Old May 19, 2008 | 09:43 AM
tcr's Avatar
tcr
By the way I don't use 4 and 5 on the quad at all, if you watch the RP gauge closely they don't help after level 3, in ramping or max psi. Also, don't be scared of level#1 on the 4.2, it is very strong on my truck, and our trucks are very much alike. Even though it's only #1 it has dynoed over 170hp w/o the quad.
